Thread: Jetta 2006 transmission problem (Egypt)
Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
  1. Re: Jetta 2006 transmission problem (Egypt)
    #11
    Oct 2009
    london england
    Hi kamal sorry that it has been so long for me to get back to you but i was quite busy how did it go in the end? i hope you finally got the problem sorted
  2. Re: Jetta 2006 transmission problem (Egypt)
    #12
    Mar 2008
    First, I really appreciate your concern and advices. in fact, I tried to do what you told earlier but the technician was resisting my suggestions. anyway, he cleaned the mass flow meter and asked me to test the performance after making the 60,000 routine maintenance. It was the same. then I asked him to fully rest the ECU, after which the car went great for 1-2 days, then it retuned back to the same low performance of high fuel consumption and slow response to acceleration with limited max speeds. I fully agree with you that that the problem is not with transmission and it is obviously with the signals going into the ECU that build a wrong mapping. Do you suggest anything in this regard? by the way we made a temporary change of the fuel pump to check if it was contributing to the problem but it was not.
  3. Re: Jetta 2006 transmission problem (Egypt)
    #13
    Oct 2009
    london england
    Hi ahmed your scan looks exceptionally healthy because you've got no faults present in the system. so most likely you might be having a mechanical malfunction,ie transmission internal failure. I didn't see the scan for the transmission control module though.
  4. Re: Jetta 2006 transmission problem (Egypt)
    #14
    Oct 2009
    london england
    mapping, well in terms of that it really sounds like you need to start getting your sleeves rolled up by getting a registered vcds lead and then download some remapping files from the ross tech website for your vehicle or you could try taking it back to the dealer to have it done.me personally i would have a go at it myself but i still cant afford the registered vcds lead yet.you need to have an idea though if you are going to get stuck in. so my advise is to let someone who know's how to do it proffessionally do it for you, as you can corrupt the ecu if the procedure is not done properly.
  1. Some one please help me am so confused here in Egypt about my jetta
    By schatten in forum Golf MK2 - 1984 - 1992
    Last Post: 16-03-2008, 01:46 AM
  2. V5 transmission/ sensor problem
    By Poal in forum Bora - 1998 - 2005
    Last Post: 31-10-2007, 03:58 PM
  3. Audi A4 transmission problem
    By jwyn in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 31-07-2007, 05:37 PM
  4. A6 ECU Auto Transmission Problem
    By thehoff in forum Archive posts
    Last Post: 30-07-2007, 01:19 PM
  5. New Member, Auto Transmission ECU Problem
    By Ballu102 in forum Archive posts
    Last Post: 18-01-2007, 06:18 PM
