Thread: Rear drivers side door wont unlock.
  1. Rear drivers side door wont unlock.
    Mar 2008
    The rear door on my 98 tdi estate wont unlock, any tips on how i can get at the mechanism or what the fault might be.
  2. Re: Rear drivers side door wont unlock.
    Open the door fully there is a rubber boot with connectors inside check the connector block hasnt come undone
    Ed
  3. Re: Rear drivers side door wont unlock.
    Mar 2008
    Problem is i cant get the door open, if i could then id be able to get at the door trim to take it off and look at the mechanism.
  4. Re: Rear drivers side door wont unlock.
    Feb 2006
    I have this same problem intermittently as well. What seems to work is
    - with engine running (eg during a journey), lock all doors using the button on the drivers door armrest;
    - at end of journey unlock doors using the same button.
    Why this works, I've no idea.
  1. Golf Mk4 rear door won't unlock
    By CrossMouse in forum Golf MK4 - 1999 - 2004
    Last Post: 17-04-2020, 12:34 PM
  2. Replies: 2
    Last Post: 17-08-2010, 10:37 AM
  3. Replies: 4
    Last Post: 08-03-2008, 12:16 PM
  4. locked rear drivers side passenger door
    By marcj in forum Passat - B5 Forum - 1997 -2005
    Last Post: 13-05-2007, 07:51 PM
