Thread: audi 80 1.9tdi estate handbrake
  1. Exclamation audi 80 1.9tdi estate handbrake
    Ebbw Vale
    how do i adjust tha handbrake cable on tha 80 1.9tdi estate??? any help plzzzz
    thanxs chris
    audi 80 1.9tdi 1z estate
  2. Re: audi 80 1.9tdi estate handbrake
    Gwent
    There should be a threaded rod adjuster under the car at the handbrake lever end. To reduce handbrake travel, take the nut up the rod a few turns.
    Take care not to adjust it too much, if you do, one or both calipers may stop self adjusting. After you have made your adjustments, you should check that both actuator levers (on the calipers) are able to return to their stops - with the handbrake off.
    2001 Passat Sport tdi 130hp
    1990 Audi coupe 20v x 2
  3. Re: audi 80 1.9tdi estate handbrake
    134 Post(s)
    2021 Post(s)
    If you need to adjust it there is a problem with the rear brakes.
  4. Re: audi 80 1.9tdi estate handbrake
    Ebbw Vale
    thanx for the advie boys
  1. Replies: 13
    Last Post: 01-04-2008, 02:24 PM
  2. Dog Guard for Audi 80 1.9 TDI Estate?
    By mangojuice in forum New Member Introductions
    Last Post: 27-02-2008, 10:01 PM
  3. Audi 80 TDi Estate - are they any good?
    By Rorty_Corty in forum 80 - 90
    Last Post: 20-02-2008, 11:22 PM
  4. 2000 passat estate 1.9tdi running probs
    By aciteen in forum Archive posts
    Last Post: 11-01-2007, 08:55 PM
  5. audi 80 estate
    By lynettejc in forum 80 - 90
    Last Post: 11-12-2006, 04:02 PM
