Thread: VW Sharan - Water Ingress
  1. VW Sharan - Water Ingress
    Mar 2008
    Reading, Berkshire
    I hope somebody can help!!! I have a 95 Sharan with the central door locking not working. I found that the cubby hole under the front passenger seat was full of water & both the ECU & Relay were rotten. I have now sourced a replacement ECU & relay. I have also just replaced the front suspension top mounts & realised that the drainage channels were completely blocked with leaves & debris, so I have cleaned this out,blown the drainage tubes out with an airline & removed the inner wheel arch liners so that I could push a wire up the drainage tubes just to ensure I had cleared them properley. I also made sure that the pollen filter was securely fitted. The new ECU & Relay arrived today, so I have just gone to fit them & the cubby hole is full of water again!! Does any body know where else this water leaks in from? The car also has a sunroof - where do its drainage channels terminate? The carpet is bone dry, its just the cubby hole that is full of water.
    Thanks in anticipation - Simon
  2. Re: VW Sharan - Water Ingress
    Tyldesley, Manchester, UK
    This sounds like the common Passat/A4 leaking gasket joint below the pollen filter, linked with the blocked drains below the battery?
  1. Water ingress
    By yendis in forum Bora - 1998 - 2005
    Last Post: 06-04-2009, 07:31 PM
  2. Water Ingress
    By handford in forum Golf MK4 - 1999 - 2004
    Last Post: 22-03-2008, 03:30 PM
  3. 1.9 Tdi Water Ingress
    By paulp in forum Passat - B5 Forum - 1997 -2005
    Last Post: 03-07-2007, 09:15 AM
  4. Water ingress.
    By Whocantellyer in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 10-03-2007, 03:57 PM
  5. Water Ingress?
    By kriskros in forum Passat - Archive Topics
    Last Post: 26-12-2006, 08:09 PM
