Thread: front bumper
Results 1 to 10 of 10
  1. front bumper
    Mar 2008
    Essex
    How easy is it to take the front bumper of of a a3 2004 modal
  2. Re: front bumper
    Jul 2007
    quite easy mate takes about 10 mins thers is a bolt either side you need to get in between wheel arch to locate bolt and obviously the 3 at the top of the grille then just pulls off
  3. Re: front bumper
    Mar 2008
    Essex
    when you say bolt in between wheel arch, where do you mean on the wheel arch under the liner? sorry to sound thick, i found the ones on the grill
  4. Re: front bumper
    Jul 2007
    right sorry i was the same took a while if you pull the wheel arch cover to the side enough to get ya hands in think you need to remove a couple of allan bolts or screws there is a plastic pin just inside right at end of bumper it easier to see if wheel off but i did it with em on when you get them off one either side try pulling the bumper off and you can see were the pressure is ie the bolts they are just below headlights 10mm bolts i think undo 1 either side then the bumper will just pull off hope this helps m8 if any probs get back to me its **** not havin a manual for these cars isnt it if you cant reach with arches on get a extension for the ratchet as you defo need to use a socket to far for a spanner m8
  5. Re: front bumper
    Mar 2008
    Essex
    cheers fella will be having a go at it at the weekend.
  6. Re: front bumper
    tooshman Guest
    could anyone reveal how to remove just the big grille, or do i have to remove the bumper to get grille out.... any help would be very much welcomed
  7. Re: front bumper
    Dec 2007
    London/Surrey
    i believe you have to remove the whole bumper to get to the grill
    COMING SOON: '14 A5 Cabriolet S-line Special edition, Daytona Grey
    CURRENT: 11' A5 S-Line Black Edition Ibis White
    previous: 09' A3 S-line Ibis White
  8. Re: front bumper
    tooshman Guest
    this is what i feared... i was hoping it wouldn't come to that. i think i will order the sports grille i've had my eye on & a set of angel lights & do the whole job in one
  9. Re: front bumper
    Aug 2008
    north hampshire
    i am now needing to take off my front bumper! was it just the 5 bolts, n obviously you have to take off the undertray too!!!!
  10. Thumbs down Re: front bumper
    tooshman Guest
    i have no idea as i have not done it yet .... i decided not to change headlights in the end & chose the cheaper option of buying a dark tint kit from the states
  1. Front Bumper Removal
    By tbarton in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 14-03-2008, 09:44 PM
  2. Front Bumper
    By sdk778 in forum 80 - 90
    Last Post: 04-03-2008, 06:28 PM
  3. front bumper
    By robbiedobbiedo in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 06-01-2008, 12:22 PM
  4. I am looking for RS6 front bumper skin
    By THM in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 02-01-2008, 03:12 AM
  5. Someone With a R32 Front Bumper
    By FLASH in forum Golf MK4 - 1999 - 2004
    Last Post: 08-11-2007, 01:28 PM
