Thread: Cooling fans
  1. Cooling fans
    dazzer Guest
    I've got a 52 PD 130 TDI Golf and as soon as I switch the engine on the cooling fans switch on straight away. They stay on till i switch the engine off. Surely they should kick in once the temperature gets too hot only? I think it might be a temperature gauge sensor. Can anyone help?
    Thanks Very Much
  2. Re: Cooling fans
    nottinghamshire
    Quote Originally Posted by dazzer View Post
    Thanks Very Much
    i noticed my fans were on the other day when the car was cold
    but when i turned the heating off the fans switched off??
    i thought there was a fan in the heater matrix to control the heating??
    im not sure
  3. Re: Cooling fans
    I noticed that too.
    The fans mounted on the front radiator come on as soon as the engine is on. I’ve got a 52 PD150 Golf.
    I don’t know if it’s right or not though. I’m sure some knowledgeable fellow will enlighten us shortly.
  4. Re: Cooling fans
    South Yorkshire
    The fans will come on as soon as the air con is switched on. If the air con is left on when you switch the ignition off, it will be on as soon as you switch on again. Thats probebly why the fans are on when the engine is cold.
    "If I hadnt seen such riches I could live with being poor"
    Passat 2.0 Sport DSG 140. 2006
  5. Re: Cooling fans
    Bath, Somerset
    They will run if you have climate and you keep it in Auto mode too. If they are running really fast though all the time and don't vary their speed, then you need a new fan unit. It is quite a common fault on the Mk4...
  6. Re: Cooling fans
    dazzer Guest
    thankyou for all your replies,but my climate is not on,ive only got the heating on 26 and the screen is clear,no auto on or economically mode.i put it on auto once every month to keep things circulating,thats about it.seems to be running faster after the journey though.what do u reckon people,many thanks.
  7. Re: Cooling fans
    Bath, Somerset
    Sounds like the temp sender has failed and the fans will run all the time as a fail safe so the car doesn't over heat.
  1. Touran Cooling Fans and 'Intake manifold flap motor problem?
    By Matt B in forum Touran - Sharan - Caravelle
    Last Post: 02-10-2009, 01:09 PM
  2. Hi All Audi fans
    By Ash333 in forum New Member Introductions
    Last Post: 22-03-2008, 11:33 PM
  3. cooling fans
    By simon74 in forum Golf MK4 - 1999 - 2004
    Last Post: 26-02-2008, 11:55 PM
  4. fans on radiator
    By charles0106 in forum 80 - 90
    Last Post: 07-10-2007, 06:38 PM
  5. Touran Cooling Fans and 'Intake manifold flap motor problem?
    Last Post: 03-01-2007, 03:55 PM
