Thread: Bit Hanging From Underneath My Car..
Page 1 of 3 123 LastLast
Results 1 to 10 of 26
  1. Bit Hanging From Underneath My Car..
    S Wales
    Golf gt tdi 130 mk4..
    It looks like a big splash plate/sort of protection for the bottom of the engine.
    Basically i'm missing 3 or 4 of whatever fixes this to the frame.
    Will there be a thread waiting (so then it's just a case of getting bolts) or is it a self-tapper job?
  2. Re: Bit Hanging From Underneath My Car..
    Mar 2008
    Barnsley
    Don't bother fixing it just remove it.
    Tryed loads of stuff to keep mine up but it always managed to hang loose after a month or so.
  3. Re: Bit Hanging From Underneath My Car..
    S Wales
    Erm, I think i'd like to fix it, it's obviously there for a reason.
  4. Re: Bit Hanging From Underneath My Car..
    Mar 2008
    Barnsley
    Its there to reduce outside noise and supposed to aid cooling of the engine.
    I cannot tell the difference TBH.
    One of the times it came down on mine and ended up caught up on the ns wheel I was on the motorway at the time and it could have caused a blow out as it damaged the inside wall of the tyre.
    I read a few other forums at the time for the same advice your asking for and the general opinion was remove it.
    With the amount of speed humps and how low the MK4 platform is it's only a matter of time before it comes down again.
    If you've gotta have it consider fitting new side mounts and the main engine shield.
  5. Re: Bit Hanging From Underneath My Car..
    Ireland
    just remove it as its only there to reduce road noise. it also makes it harder to change the oil.
  6. Re: Bit Hanging From Underneath My Car..
    S Wales
    I'm still reluctant to remove it though. Gonna have a bash at fixing it proper tomorow, if I can't then i'll remove it.
    Cheers boy.
  7. Re: Bit Hanging From Underneath My Car..
    May 2007
    Birmingham
    Mine came loose as well and i had it reattched twice but it kept coming loose and scraping over humps. I could even hear the wind blowing on it on the motorway (couldn't have been good for fuel consumption). Anyway i removed it last week and i dont regret it. No more scraping noises and i cant notice any difference in road noise etc
    TRUST ME! MY THINGS ALWAYS WORK (SOMETIMES)
  8. Re: Bit Hanging From Underneath My Car..
    Southampton, UK.
    The plastic tray has about 8 or so torx (T20 size I think) screws dotted around the outside of it. The are several lips on the front part the tray, that then slides into the bodywork at the front of the car. Honestly can't remember whether the screws have an additional metal clip thing that hooks onto the body or whether they screw straight into a threaded type hole.
    Nevertheless, I'd tend to agree that the tray is there for a reason. Probably to stop muck splashing up into the engine bay and to protect the aluminium sump from road debris.
  9. Re: Bit Hanging From Underneath My Car..
    S Wales
    Quote Originally Posted by herby0001 View Post
    Cheers mate.
    Ok, now for the silly question..
    Would any of you do work under just a jack? To be honest I don't think it's the best idea, my mates grandfather has a pit I used to use, but thats a no go for 2 weeks as the wrinkly is in Teniriffe.
  10. Re: Bit Hanging From Underneath My Car..
    Southampton, UK.
    Quote Originally Posted by Stuart_B View Post
    Cheers mate.
    Not silly at all, but a genuine safety question. A pit or a ramp is the ideal facility to have.
    When I do an oil change, I jack the car up on one side, whack two breeze blocks in next to the jack. This lets me get underneath the car without me worrying about meeting St Peter too early. Then I can remove the screws and then the sump plug. Anyway, then lowering the car back down allows me to continue with the work. Little bit of hassle, but peace of mind included. You could buy a set of axle stands from ********* too. As long as you don't mind lying on your back to work underneath the car, that should be sufficient.
  1. A3 rattle underneath - exhaust, cat converter?
    By pds999 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 07-03-2008, 07:51 PM
  2. Golf mk4 underneath engine cover
    By Primo1000 in forum Golf MK4 - 1999 - 2004
    Last Post: 25-01-2008, 11:23 PM
  3. Kick plate/trim hanging off!
    By jonbaker in forum Audi A4 - Archive Topics
    Last Post: 16-01-2008, 07:16 PM
  4. Clicking/Rumbling from underneath glovebox
    By TDiBoraSam in forum Bora - 1998 - 2005
    Last Post: 23-08-2007, 01:11 PM
  5. Water hanging under battery
    By vroooOOOM in forum Reviews & Recommendations of Dealers & Independant Garages
    Last Post: 17-06-2007, 10:10 PM
