Thread: Heavy Clutch
Page 1 of 4 123 ... LastLast
Results 1 to 10 of 38
  1. Heavy Clutch
    Mar 2008
    HI I'm looking at a 1.4 cl and noticed the clutch is very heavy to operate. Is this a sign of a problem or just the way they are. Its a 93 with 65K on the clock but there is no slipping just heavy operation.
    cheers
  2. Re: Heavy Clutch
    Mar 2008
    Well I bought it and was wondering if the clutch cable is at fault is it a common problem???
  3. Re: Heavy Clutch
    Apr 2007
    Coventry
    mmm ive got a 19tdcl and my clutch is quite heavy, and "sticky" I was wondering if it should need replacing. I probably will.
  4. Re: Heavy Clutch
    Mar 2008
    I've been told the splines need stripping and cleaning but to be honest i think i'll go for a new one as the pedal creak is driving me mad
  5. Re: Heavy Clutch
    Quote Originally Posted by wayne3940 View Post
    How do they know that bud? Have they had the car in and gearbox out?
    2019 Urus, 2020 RS7
    2014 RS6, 2018 RS5, 2016 RS3, 2019 RS3
    2011 RS5, 2008 S5 V8
    2007 A4 2.0, 2008 Passat 2.0 TDI
    2005 Bora 1.9 TDI, 2000 Bora 1.6 , 1989 Polo 1.4
  6. Re: Heavy Clutch
    Mar 2008
    No its a best guess but if the plates aren't slipping it has to be the mechanics of the thing.
    How much is a good price the best I've got so far is 150 quid
  7. Re: Heavy Clutch
    Mar 2008
    Nuneaton
    150 for the clutch?
    I've seen them going on eBay for 109 - 130
    Sounds about right.
  8. Re: Heavy Clutch
    Mar 2008
    Nah £150 fitted you can buy a clutch from Eurocar parts for £60 but fitting one is beyond me.
  9. Re: Heavy Clutch
    Thats kinda my point bud - theres no real way of telling what the problem is without getting the gearbox off. Telling you 'the splines need stripping' apart from not really making sense, is just leading you up the garden path.
    The splines only really bugger up if some muppet has put copper slip on them thinking its a high temp grease which its not. If the clutch has been in there from new, 99% sure they'll be fine.
    If you pedal is creaking, it could be a pedal issue not clutch. Get the pedal looked at/changed first - its a much cheaper and faster job
    If youre buying from euro car parts - make sure they dont supply a 'Transmec' brand in a black and green box. Theyre not original equipment. As long as its a brand luk/valeo/sachs theyre practically the same in the boxes.
    2019 Urus, 2020 RS7
  10. Re: Heavy Clutch
    Mar 2008
    Quote Originally Posted by Pauloz View Post
    Hi I've just spotted you're a clutch specialist so here's all the symptoms. The clutch is very heavy with a creak from the pedal that drives me nuts.
    The bite is quite near the top but not all the way and doesn't slip at all but the clutch pedal seems to sit a bit higher than the brake inside the car.
    Reverse seems to be a bit tricky sometimes and crunches about 50% of the time I try to engage it. The car has 62K on the clock and I have no idea if the clutch was ever changed. Any ideas??????
  1. Heavy Clutch
    By Alun in forum Golf MK3 - 1993 - 1999
    Last Post: 07-01-2008, 10:02 PM
  2. Passat - Heavy duty clutch?
    By RobBentley in forum Passat - Archive Topics
    Last Post: 28-10-2007, 12:46 AM
  3. heavy on the juice
    By mick1 in forum Bora - 1998 - 2005
    Last Post: 17-09-2007, 06:24 AM
  4. Heavy Clutch
    By Alun in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 13-08-2007, 10:22 PM
  5. How heavy is a slab
    Last Post: 12-05-2007, 02:14 PM
