Thread: rer wash leaked. rear lights not working
  1. rear wash leaked. rear lights not working
    Aug 2007
    hi all.
    i recently repaired my rear wash as it would not spray, unfortunately this has caused a leak at the jont into the wash motor housing. The fall out from which has leaked onto the boot lock mechanism. My rear lights are now not working, is this linked to the leak and if so do i need to just dry out the boot lock mechanism or replace it.
    Typical... I create a problem by solving a problem. I can't win!
    Dave.
  2. Re: rer wash leaked. rear lights not working
    nottinghamshire
    could be something to do with the water
    i had a problem with my lock when my rear wash leaked, but not the lights
    but i have read that some plp have had a problem with the boot light being on all the time when the r/wash leaked
    try stripping the boot panel and have a look
  3. Re: rer wash leaked. rear lights not working
    S Wales
    Well first and foremost, you need to sort out the leak.
    Secondly, you've probably blown a fuse for the lights so check your fuses..
  4. Re: rer wash leaked. rear lights not working
    Angus, Scotland
    Yeah, the Mk4's are prone to that in the winter.
    Best thing to do is check your fuses and then take the panel off of the inside of the boot lid and get everything as clean as possible using clean warm water and then dry it up as much as you can.
    If I remember rightly, I had to get a new motor/washer jet unit when mines went, here's hoping I was just unlucky as I think it was quite expensive!!
    Paul
    A4 B7 S-Line 140 TDi
    Phantom Black, Bose Sound System, Arm-Rest, Retro-Fit DIS, Retro-Fit Cruise
    Fully registered Vag-Com/VCDS Hex-CAN
  1. Rear Wash Wipe Tubing
    By s4k1b in forum Golf MK4 - 1999 - 2004
    Last Post: 12-02-2008, 05:09 PM
  2. rear lights not working!! golf mk4 gti
    By scottywales in forum Golf MK4 - 1999 - 2004
    Last Post: 07-01-2008, 05:01 PM
  3. Rear wash on Avant not working
    By ingo67 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 19-09-2007, 10:36 AM
  4. rear wash
    By davegilsenan in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 30-07-2007, 09:13 PM
  5. Replies: 7
    Last Post: 06-07-2007, 06:12 PM
