Thread: Alternator change.
  1. Alternator change.
    Jun 2007
    Hello all.
    I've got a year 2000 Ibiza 1.9sdi which has a noisy alternator freewheel clutch mechanism. I know I have to release the aux belt tensioner and I'm sure that is done by the nut in the centre by turning it clockwise to allow the belt to be removed. It appears though, that the alternator fixing bolts are behind the tension block which looks like it's bolted to the engine block. Is it just a case of undoing the bolts and removing it allowing me to get to the alt fixings or is it more involved. Finally after refitting the aux belt does the tensioner take up the slack automatically.
    Phew! Hope that is not as difficult as it sounds...
  2. Re: Alternator change.
    Oct 2007
    Hi Yes Yes and Yes
  3. Re: Alternator change.
    Jun 2007
    Thank you for that, i'll get on with it over the weekend. Any other tips for me to think about?
    David.
  4. Re: Alternator change.
    Jun 2007
    All done and dusted. Quite an easy job, the only diddficult bit was trying to hold the tensioner and replace the aux belt, three hands needed in the space for two.
    Thanks for your help.
  1. Replies: 0
    Last Post: 23-01-2008, 09:53 PM
  2. alternator
    By salty in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 30-12-2007, 02:24 PM
  3. Aux. belt and alternator pulley change/queries
    By dvhttn in forum Passat - Archive Topics
    Last Post: 22-03-2007, 08:29 PM
  4. Alternator
    By 150bhpforestboy in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 18-03-2007, 09:55 PM
  5. alternator
    By gibby45 in forum Passat - Archive Topics
    Last Post: 09-11-2006, 10:08 PM
