Thread: 97 Golf TDI, cuts out after driving a short distance
  1. 97 Golf TDI, cuts out after driving a short distance
    Hi I have a Golf TDI, I can start out in the morning, after a mile it dies. I then start it up again and away I go - any ideas?
    VAG tests brought nothing up!
  2. Re: 97 Golf TDI, cuts out after driving a short distance
    hi there, i had the same problem with my TDi. my local VW Audi specialist said it'll be the 109 relay (it was either 109 or 9). he changed that for about £10 and it's been fine since. if you mention it at the garage they'll know what you mean if you say both them numbers i should imagine. hope this helps if you haven't had it sorted yet.
    regards, Dan.
  3. Cool Re: 97 Golf TDI, cuts out after driving a short distance
    May 2009
    Southend on sea United Kingdom
    My Tdi Veno are also cutting out after a couple of miles, it can happen warm or cold. I discover that the fuel solenoid on the fuel pump cutting the fuel supply off. I bridge it temporarily with a wire from the battery, which had solved the problem that means something is breaking the power supply.
    I am surely going to replace the 109 relay and will keep you posted it have the longing effect.
    Thanks Duan
  4. Re: 97 Golf TDI, cuts out after driving a short distance
    Jun 2008
    Lichfield, Staffordshire
    when the engine cuts out, does the speedo zero even with the car coasting?
    if it does, it points to electrical fault (speedo is electronic).
    My fault was the 109 relay. I soldered the bad connections in the relay myself and it's been perfect since.
    hope this helps
  5. Re: 97 Golf TDI, cuts out after driving a short distance
    Nov 2008
    folkestone.kent
    yes they do tend to go wrong but a new one isnt expensive.. if your bridging the solenoid it wont have full power but it will get you out of trouble !!.....
  6. Re: 97 Golf TDI, cuts out after driving a short distance
    May 2009
    Thanks;
    I replaced the 109 relay with a £2.00 one off a tdi in my local breakers yard. It worked first time and No problems since then!!!
    GREAT FORUM
    Duan Vogel
  1. GOLF MK3 1.8 cuts out when going through puddle
    By markymark94 in forum Golf MK3 - 1993 - 1999
    Last Post: 08-02-2010, 04:38 PM
  2. mk3 golf 1.4cl cuts out at speed
    By nev1113 in forum Golf MK3 - 1993 - 1999
    Last Post: 11-10-2007, 11:09 PM
  3. Replies: 8
    Last Post: 11-09-2007, 11:06 AM
  4. Engine cuts out on Mk 3 Golf TDI
    By Paul C in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 13-04-2006, 06:44 PM
