Thread: pressurizing vw passat 1.9tdi
  1. pressurizing vw passat 1.9tdi
    Mar 2008
    hi all im in need of help here ive a 1998 vw passat tdi red i 115bhp its got 215k on clock it been driving great until i decided to change the water in the system as theres been no antifreeze in the rad and it been cold here like freezing,
    anyways i drained her down and when i did there was a lot of rusty water so i thought the theromastate was rotton i took it out and its like new i replaced it anywayz filled up the system and now it pressurizing i dident boil it as i wasent driving it after i drained it down o yea i put bars flush in first thinking it would clear its self (rust i mean) pipes on the car at the tops of them are hot and bottom of them cold can anyone offer me some help is the engine done
  2. Re: pressurizing vw passat 1.9tdi
    west yorkshire
    you could have a air lock or you head gasket could have gone
    86 WR/MB UR mine
    00 A4 bus mine
    87 CQ the wife's
    99 A4 bus the wife's
    www.audi.heavenforum.com www.quattroforum.com
  3. Re: pressurizing vw passat 1.9tdi
    Aug 2007
    Welcome to the forum, you might be best posting in the Passat topic for a better chance of an answer. Good luck!
  4. Re: pressurizing vw passat 1.9tdi
    Mar 2008
    well jsut getting back now with the solution dam head cracked just got a new engine in her only now the timing in the diesel pump needs adjusted car runs great when started but hard to start ok i done the heater plugs and still the same so its the timing on the diesel pump any ideas how to set it up guyz and can a novice do it thanks again
  5. Re: pressurizing vw passat 1.9tdi
    Coventry
    welcome to the forum
  1. Passat 1.9tdi se accelerate on it own
    By newboy999 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 07-01-2008, 06:35 PM
  2. VW passat 1.9tdi accelerate on its own
    By newboy999 in forum New Member Introductions
    Last Post: 06-01-2008, 10:00 PM
  3. passat 1.9tdi, oil in air inlet
    By southamptonadi in forum Archive posts
    Last Post: 17-11-2007, 05:13 PM
  4. Low Power Passat 1.9TDi 115 PD
    By Fizzwizz in forum Archive posts
    Last Post: 21-11-2006, 09:11 PM
  5. OIL CONSUMPTION IN NEW PASSAT 1.9TDI
    By mac500 in forum Passat - Archive Topics
    Last Post: 02-05-2006, 03:45 PM
