Thread: VW Golf 1.4 S 16v Camshaft Sensor Problem
Results 1 to 10 of 13
  1. VW Golf 1.4 S 16v Camshaft Sensor Problem
    Jul 2007
    VW Golf 1.4S 16v Camshaft Sensor Problem
    My 98 Mark 4 Golf 1.4 S 16v is showing a diganostics problem Camshaft Position Sensor Earth to Ground, also there is lack of power at low revs and a dip in power at 2000 - 2300 rpm, above 2500 rpm it goes like the clappers, can anyone help me to resolve this problem.
    I have changed the ignition coil and the camshaft sensor.
  2. Re: VW Golf 1.4 S 16v Camshaft Sensor Problem
    Hi Since you have replaced the sensor and with the reading you are getting i would imagine there is something wrong with the wiring.To check the sensor properly it needs to be scoped
  3. Re: VW Golf 1.4 S 16v Camshaft Sensor Problem
    Jul 2007
    What do you mean Scoped?
  4. Re: VW Golf 1.4 S 16v Camshaft Sensor Problem
    electronic equipment that provides visual images of varying electrical quantities
  5. Re: VW Golf 1.4 S 16v Camshaft Sensor Problem
    Jul 2007
    How do you do this and can I get the wiring checked?. There are 3 wires going to the Sensor and then they join into the loom.
  6. Re: VW Golf 1.4 S 16v Camshaft Sensor Problem
    Hi You have to ohm the wires give me your engine code and i will tell you were and how to check them. Most modern workshops have equipment to scope components,however i think you should consentrate on the wires.
  7. Re: VW Golf 1.4 S 16v Camshaft Sensor Problem
    Jul 2007
    Is there any simple test I can do, when I disconect the Sensor and test driver the car there is no difference at all in fact I think its better.
  8. Re: VW Golf 1.4 S 16v Camshaft Sensor Problem
    Kings Lynn
    If the fault is electrical, the two common places to look are the earth connections, one under the battery (there should be several connections) the other is under the scuttle panel in front of the engine e.c.u
    however the camshaft sensor could be detecting that the camshaft and crankshaft aren't in perfect timing with each other. i.e the cambelt is a bit slack.
    how long ago was it changed? or has it (i say "it" but it actually has two)
    i know im swearing when i say vauxhall, but they suffer with camshaft sensor faults, normally being down to the cambelt.
  9. Re: VW Golf 1.4 S 16v Camshaft Sensor Problem
    Jul 2007
    That's very interesting I bought the car in June last year and I was told the Timing belt was replaced. I have been told that if you don't replace the complete Timing belt kit (belt & tensioners) this could throw up this problem.
  10. Re: VW Golf 1.4 S 16v Camshaft Sensor Problem
    No signal
    - Fault in power supply or earth connection for -G40
    - Engine no longer runs up to cut-off speed (engine speed governed to approx. 5100 rpm)
    Implausible signal
    - Faulty signal input in engine control unit (control unit defective)
    - Engine starts reluctantly or not at all when cold (cold start problems)
    - Open circuit or short to positive or earth in signal wire between -G40 and engine control unit
    - Engine starts reluctantly or not at all when warm (hot start problems)
    - Rectify open circuit or short using current flow diagram
    Possible causes of fault
    Possible effects
    Fault remedy
    Hall sender -G40
    (cont.)
    - -G40 defective
    - Loss of power
    - Toothed belt has jumped tooth (signal does not occur at point expected)
    - - Check engine valve timing:
    - Rotor trim defective (bent, cracked)
  1. Golf TDI mk4 - Boot sensor problem!
    By Jujuman in forum Golf MK4 - 1999 - 2004
    Last Post: 20-07-2013, 11:49 PM
  2. VW Golf 1.4S 16v Camshaft Sensor Problem
    By Kevon29 in forum Golf MK4 - 1999 - 2004
    Last Post: 05-03-2008, 05:34 PM
  3. passat camshaft sensor
    By billza1967 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 18-02-2008, 03:23 AM
  4. Golf Mk4 external temprature sensor problem
    By fluberjack in forum Archive posts
    Last Post: 05-01-2008, 08:51 PM
  5. Camshaft Sensor (G40) - where is it?
    By Mat456 in forum Golf MK3 - 1993 - 1999
    Last Post: 25-12-2007, 11:00 AM
