Thread: Locking wheel nut problem
Results 1 to 10 of 11
  1. Locking wheel nut problem
    Have purchased a new set of wheels but my old set has locking wheel nuts and I haven't got the adapter for them. Any ideas where I can get one?
  2. Re: Locking wheel nut problem
    Chester-le-Street, United Kingdom
    Quote Originally Posted by pg20 View Post
    if they are originals, why not try the dealer?
    first time i was up a ladder i was down a well
    4th cog,--two to go
  3. Re: Locking wheel nut problem
    Never thought of that one????? Anyone else got an idea?
  4. Re: Locking wheel nut problem
    how about ANOTHER dealer
    4th cog,--two to go
  5. Re: Locking wheel nut problem
    Mar 2008
    hello i had a problem like yours on a cavalier years ago and the only way i got them off was getting some pipe and putting it over the nut and welded it then undone with gripps but that was because they didnt make that type of nut no more hope this of some help
    cookie boy
  6. Re: Locking wheel nut problem
    Apr 2009
    Sussex
    Had a similar problem recently with a broken wheel nut lock, called a company called dynomec (01977 520666) they make a tool for removing any type of locking nut. They only sell to the trade, but will put you in contact with a local tyre fitter / garage that has their equipment.
  7. Re: Locking wheel nut problem
    Feb 2009
    gliwice, Poland
    If you have some old sockets that you dont mind sacrificing, that are slightly smaller than the diameter of the locking wheel nut. you could get your sledge hammer out and bang them on. Then it's be a case of just undoing as normal.
    If you have a handy bench vice, you may even be able to remove the locking nut from inside the newly created 'locking wheel nut socket' each time, by hammering it out with a screwdriver or equivalent through the hole in the socket and move onto the next wheel.
  8. Re: Locking wheel nut problem
    Apr 2007
    Going to a dealer is worked for me! After getting a flat, I foolishly lost the locking bolt. I took it my local dealer and they had a box of about 20 different locking nuts which they tried until I found the correct one. They didn't have a new one in stock, but I needed to get the tire changed as the spare tire was old so I simply undid the locking bolt with the garage's copy and drove with just four nuts to get the tire fixed. (replacement locking nut key was about 15 quid)
    1999 Audi A4 1.8T Quattro Sport Saloon (180bhp)
  9. Re: Locking wheel nut problem
    Apr 2009
    Sussex
    trouble is hammering on an undersized socket doesn't work on the types of locking wheel nut that has the rotating ring around the top.
  10. Re: Locking wheel nut problem
    Feb 2009
    gliwice, Poland
    Mine dont have a rotating ring, just a few grooves on a cylinder. In fact i'd never even heard of them. Just goes to show, you learn something new every day.
    Sounds like a clever invention to foil the attack i suggested above. I assume this rotating ring is slightly bigger in diameter than the rest of the body of the nut?
  1. Locking wheel nut *@?/.<d
    By JPQuattro in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 23-12-2007, 09:37 PM
  2. Locking Wheel Nut Spanner
    By davidhardie in forum Passat - B5 Forum - 1997 -2005
    Last Post: 20-11-2007, 04:53 PM
  3. A4 Locking Wheel Nuts
    By gazd in forum Audi A4 - Archive Topics
    Last Post: 18-10-2007, 09:33 PM
  4. wheel locking nut
    By yogise in forum Passat - B5 Forum - 1997 -2005
    Last Post: 20-04-2007, 08:02 AM
  5. Audi A6 - 2004-present - locking wheel nuts
    By audi_jimbo in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 05-02-2007, 01:37 PM
