Thread: Car Misting up occasionally
  1. Car Misting up occasionally
    skodasteve Guest
    My car has misted up inside a couple of times even when the Climatronic is set to auto, any ideas, does it need an aircon recharge ?
  2. Re: Car Misting up occasionally
    Gloucestershire
    Hi, used to have the same issue with my Passat, i changed the pollen filter and also used one of those diy air-con system cleaner, seemed ok after that.
    http://www.halfords.com/webapp/wcs/s...tegoryrn_35126
    Assuming all your carpets, mats etc are dry and not damp.
    Audi A3 1.8 20v 1998
    Audi A6 2.5 TDi 1996
  3. Re: Car Misting up occasionally
    Jul 2008
    I'd say pollen filter as well.
  4. Re: Car Misting up occasionally
    Mar 2008
    Just Cumbria now.
    Check the drains also;
    1. Under Battery
    2. Under Brake Servo
    If these are not clear BIG problems can ensue.
    Nothing to see here, move along..
  5. Re: Car Misting up occasionally
    Jun 2008
    London
    Quote Originally Posted by primey View Post
    I have a similar issue right now, just changed my pollen filter and it's got worse!!! Will be checking the re-circ flaps later as well as all the carpets for dampness.
    Seriously considering a visit to ********* also, that looks like good value for £10! (obviously depends on what they actually do and if they know what they are doing when they do it, if you know what I mean!!!
  6. Re: Car Misting up occasionally
    DSG4ME Guest
    Check that the A/C clears it, if it does and you switch it off the windows will fog back up, also hot ppl in a cold car doesn't help either.l
  1. golf gt tdi (115bhp) 1896 cc, year 1999 Loses Power Occasionally!!
    By karena in forum Golf MK4 - 1999 - 2004
    Last Post: 07-11-2010, 08:02 PM
  2. Stop ((ABS)) Warning light occasionally lit
    By headache56 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 23-01-2008, 05:27 PM
  3. Misting when air con off
    By jep303 in forum Passat - Archive Topics
    Last Post: 02-01-2008, 05:34 PM
  4. mk3 97 gti 8v occasionally stalls when clutch disengaged
    By svenema in forum Golf MK3 - 1993 - 1999
    Last Post: 07-12-2007, 10:43 PM
  5. Misting Windsceen
    By Gordy000 in forum Passat - Archive Topics
    Last Post: 11-12-2006, 03:41 PM
