Thread: Question about the diesel pump
Page 1 of 4 123 ... LastLast
Results 1 to 10 of 32
  1. Question about the diesel pump
    Hi.
    On my 99 Passat Syncro 1.9TDI (110 hp) the dieselpump has stopped. Im thinking of the pump located in the diesel tank. I measure +12V on the connector under the back seat when i try to start the car. But it wont start.
    My question is: Can i use a pump from a 2000¨Passat 1.9TDI with 115 hp? Is it the same pump, will it fit?
  2. Re: Question about the diesel pump
    Sep 2007
    yorkshire
    This is a non PD engine right? Whats the engine code?
    2003 AUDI AVANT SPORT TDI
  3. Re: Question about the diesel pump
    AFN/AVG ... im not quite sure about that. It is a non PD engine, thats right.
    I dont know what engine the 115hp car has, only that it is a 1.9TDI.
    I compared my car with my friends car, a 2002 1.9TDI 130 PD engine. The connector under the seat looked similiar. And i measured the same voltage at the same pin.
  4. Re: Question about the diesel pump
    135 Post(s)
    2036 Post(s)
    PM me your reg number.
  5. Re: Question about the diesel pump
    Sep 2007
    yorkshire
    Your freinds car has the PD engine with the intank lift pump fitted. Yours is different, and the mechanical pump does all the work, sucking the fuel from the tank etc...
    So no a 115bhp pump will not make any difference or make your car start.
  6. Re: Question about the diesel pump
    Are you sure about that? My dealer told me there is a electrical pump in the tank. And that there where differences between FWD and 4WD cars. Dont know if thats true. Autodata also tells me there is a electrical pump fitted in the tank
  7. Re: Question about the diesel pump
    Sep 2007
    yorkshire
    Quote Originally Posted by rotax800 View Post
    Don't see how 4 and 2 wheel drive would matter!
    If your car has an injector pump under the bonnet, This does the work of drawing fuel up to the pump.
    I may well be wrong, I honestly could not comment on what the dealers have said.
    Crasher is this true!
  8. Re: Question about the diesel pump
    Thats what the dealer told me in the beginning. He didnt know there was a pump in the tank. But when he checked it out he found out there was a electrical pump fitted in the tank. That means there are two pumps. The one in the tank, and the injector pump under the bonnet.
  9. Re: Question about the diesel pump
    Sep 2007
    yorkshire
    If this is true! Try Gravity feeding the injector pump with diesel.
    Useing a funnel and some pipeing connected to the fuel intake on the pump.
  10. Re: Question about the diesel pump
    The injector pump has a impeller inside of it this pressurises the fuel enough to open the injector nozzles it does not have the suction to draw its own fuel from the tank.The easiest way to check if your pump has gone is to disconnect the fuel inlet from your fuel filter and turn the ignition on if fuel pumps out everywhere its not the pump if not it is,dont know if the 2 pumps are interchangable
    Ed
  1. Diesel Pump Question
    By ghee60 in forum 80 - 90
    Last Post: 04-04-2009, 10:32 PM
  2. 2.5 tdi diesel pump
    By tractorboy985 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 28-02-2008, 11:44 AM
  3. mk4 130 gt tdi diesel pump
    By johnmillie in forum Golf MK4 - 1999 - 2004
    Last Post: 26-01-2008, 08:44 PM
  4. A6 94-97 AAT-AEL diesel pump
    By dean warren in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 15-01-2008, 06:46 PM
  5. VW injection pump question
    By CDK in forum Archive posts
    Last Post: 05-10-2007, 10:42 PM
