Thread: Dash Lights
  1. Dash Lights
    Gloucestershire
    Has anyone ever changed any of the dash clock lights on a 1994 80e saloon, also all the heater control bulbs do not seem to work either, i've only just got the car and these niggles were present, all the fuses are ok, is this just likely to be a bulb issue? The only bulb out on the instrument fascia is the clock, the others seem fine.
    Any ideas?
  2. Re: Dash Lights
    Gwent
    The dash bulb is likely to be just the bulb, as the others are working. To remove the dash you have to remove the upper half of the steering column shroud (3 screws on the underside.) You can then see the dash screws at the bottom, take these out and the dash should be able to be removed. Removing the steering wheel makes life easier but should not be necessary.
    The heater bulbs again could just be the bulbs, I had a car where all 3 were bad? To get to these, the heater control knobs need to be removed, grip the knob with pliers (line the plier jaws with card to prevent damage) A sharp yank rearwards should release the knob, repeat on the other 2. The screws which hold on the control panel fascia trim can be seen (where the knobs were) remove these and the bulbs can be accessed.
    2001 Passat Sport tdi 130hp
    1990 Audi coupe 20v x 2
  3. Re: Dash Lights
    Gloucestershire
    Ok, i'll have a go at that, like you say hopefully just the bulbs in the heater panel, off to Halfords i go!!!
    Many thanks for that.
    Audi A3 1.8 20v 1998
    Audi A6 2.5 TDi 1996
  4. Re: Dash Lights
    Gloucestershire
    Result, all three heater bulbs were shot, at a cost of £1.50 for all three, now working brightly!!!
    Not got around to the dash bulb yet, ran out of time!!!
  1. Dash lights
    By Bilbobaggins in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 09-12-2007, 12:32 PM
  2. Dash Lights :(
    By Nitro in forum Audi A4 - Archive Topics
    Last Post: 30-11-2007, 03:37 PM
  3. Dash Lights
    By chris.fulton in forum Golf MK4 - 1999 - 2004
    Last Post: 08-11-2007, 04:05 PM
  4. dash lights
    By howez in forum Passat - Archive Topics
    Last Post: 31-03-2007, 12:48 AM
  5. golf dash lights
    By bert in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 30-11-2006, 08:14 PM
