Thread: cooling 2.5 tdi t4
  1. Unhappy cooling 2.5 tdi t4
    Mar 2008
    can any one tell me what the second pump on the cooling system does found to be not working full of scum and what looks like radweld
  2. Re: cooling 2.5 tdi t4
    Gloucesterhire
    If the pump you are refering to is the one down under the rad,the electric one,its an afterun pump to circlulate the coolant on turn off round the block and head to stop warpage of the head and joint,head is Alloy// block is Cast.
    It only actuates at a temperature off between 217 - 219 degrees F and is fired off a 2nd sensor on the engine.
    Jeff
    T5 LWB 2007 102 Transporter Imapped to 135ps,running 9j Mugello alloys & low profiles.
  1. a6 cooling fan trouble
    By wilsy5 in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 16-10-2007, 11:44 PM
  2. cooling fan
    By mike d in forum The Commercial Range
    Last Post: 02-07-2007, 11:47 AM
  3. Cooling Fan On All the Time..?
    By Pimped-Passat in forum Passat - B5 Forum - 1997 -2005
    Last Post: 14-05-2007, 12:52 PM
  4. Erratic Cooling Fan
    By MOTOW in forum Audi A3 - Archive Topics
    Last Post: 08-04-2007, 09:33 PM
  5. pd 130 electric cooling fan
    By c12weddi16 in forum Passat - Archive Topics
    Last Post: 11-03-2007, 05:10 PM
