Thread: Airbag Light
Results 1 to 9 of 9
  1. Airbag Light
    I've got a 95 Tdi and I had the instrument cluster out to replace some of the backlighting bulbs. Ever since I put it back I get the airbag light on for about 3-5mins then it goes away. Ive checked to see if I have disturbed anything, which I cant see if I have. I also get IN 2 flashing where the mileage is displayed, not sure if that has anything to do with it.
    Anybody got any ideas?
  2. Re: Airbag Light
    Hi If you had the steering wheel off without removing one of the battery terminals then there will a fault code regisetered in the air bag control unit. IN2 your car is crying out for a servis
  3. Re: Airbag Light
    Thanks Kenney.
    No haven't had the steering wheel out, just the instrument cluster. The airbag light never game on before I took the cluster out. Is there an easy way of clearing the fault code or is it through the diagnostic port? I'm assuming its not a hard fault due to the light clearing.
  4. Re: Airbag Light
    Hull/East yorkshire
    Hi there
    in Your case only 1 way to check it is to plug vag tool and chcek for fault codes it might be anything so its worth check it. On my previous A4 I had fault from side AIRBAG but that is the safety thing but your fault will be one of the easy ones that means feed lost and just only one way via vag tool. Have fun its only A4 .....
  5. Re: Airbag Light
    Off to the ******** tomorrow to pick up some bits, so going to try and get them to read the fault codes.
  6. Re: Airbag Light
    Sep 2007
    Lincolnshire
    Dude15,
    When and if you get this sorted, can you post the result? I've got the same problem and it's driving me nuts!
  7. Re: Airbag Light
    Clarkus,
    Sorry for the delay, only just got this sorted. I bought a cheap VAG-COM cable off Ebay and had trouble getting it to work. Got there tonight though. I used the shareware copy of VAG-COM and clear the fault. Airbag now sorted, light doesn't stay on for the first copy of minutes.
  8. Re: Airbag Light
    Quote Originally Posted by Dude15 View Post
    Clarkus,
    what shareware copy did you use? i have used the software downloaded from the cable suppliers and have had no sucess
  9. Re: Airbag Light
    Quote Originally Posted by solorider View Post
    I used the VAG-COM 409.1 Serial, even though the cable is a USB, because it's a USB-Serial convertor
  1. Airbag Light - PLEASE HELP
    By abugarcia in forum Jetta MK3 - 2005 - 2013
    Last Post: 12-01-2009, 11:46 PM
  2. a4 airbag light
    By fatfighter in forum Audi A4 - Archive Topics
    Last Post: 10-11-2007, 11:15 PM
  3. Help airbag light
    By eds in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 26-05-2007, 05:40 AM
  4. A3 airbag light
    By JohnnyB in forum Archive posts
    Last Post: 19-03-2007, 10:03 PM
  5. Vag Com / Airbag Light
    By thefoolmccool in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 15-02-2007, 05:21 PM
