Thread: No cabin heat!!!
  1. No cabin heat!!!
    Nov 2006
    Ive just bought a lovely 97' A4, that drives like new, but the cabin heater doesnt work!!! The blower is fine, and there is a token gesture of warm air after 20 mins of driving, but no where near the normal. In this weather, apart from my **** being frozen, the window doesnt demist.
    Both pipes from the engine into the cabin area are hot, and the blower works fine. so why no heat?
    Can anyone tell me any short/long term fixes, costs and if its a garage or DIY job.
    Regards
    New boy Matt.
    ps. theres no A/C. (unfortunatly)
    Tyldesley, Manchester, UK
    Even though they are hot there could still be a an airlock somewhere. Does the temp gauge read normal after 20 mins or so?
    Short of emptying the coolant and flushing water through (hose) can't suggest much else.
    Years ago in my old MKIII Cortina I had similar problems. It improved for awhile after replacing the thermostat, but eventually would revert back to blowing only warmish air.
    One German, Two Italian.
    Got to agree it doe's sound like an airlock. I'm not sure of the system on your A4 but if both pipes through the bulkhead are getting hot it would surgest some flow. Have you tried giving all the hoses a good squeeze with the expansion cap off?
    Regards Boardboy
    P.s I just remembered my Golf had two safety valves fitted.So if the heater matrix burst they'd stop the flow in to the car. I think they weren't that reliable and would restrict the flow regardless of a leak. Anything like that fitted on your A4?
    Nov 2006
    Oldham, Manchester, UK
    No suggestion from me but welcome aboard mate.
  1. Cabin FLOOD!!!
    By Lord Nelson in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 14-05-2007, 07:51 PM
  2. No Heat in 88 90Q
    By AdirondackQ in forum 80 - 90
    Last Post: 12-02-2007, 09:04 PM
  3. Smell of hot oil in cabin
    By neilp in forum Passat - Archive Topics
    Last Post: 26-01-2007, 11:28 PM
  4. 1.9TDi 130 Sport Exhaust/Heat shield noise
    By landon in forum Passat - Archive Topics
    Last Post: 14-08-2006, 07:56 PM
  5. Audi turns up the heat for A4 Cabriolet range
    Last Post: 23-07-2005, 07:54 PM
