Thread: oil in water coolant
Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
  1. Re: oil in water coolant
    Canada
    Oil cooler for sure
    VW/Audi have bee using a oil cooler/oil temp stabiliser for years I had a 1983 VW Van with one,My Golf MK1 1990 had one.It sits between the oil filter and the oil filter housing and has a water jacket made of alloy. the water eats away at the jacket and then mixes the oil and water. Very common problem.
    The reason is that conventional oil cooler can over cool the oil, when what is required is a stable oil temperature to get the best results. A standard oil cooler is fine on a car driven hard all the time as your just trying to keep it from cooking
  2. Re: oil in water coolant
    Jul 2007
    Cheshire, or my A6
    So, rather than an oil cooler, it is more of an oil warmer/oil temp stabiliser? That must mean that water does in fact go to the oil 'cooler'. Now it makes sense...
    It's an oil cooler problem.
    Paul
  3. Re: oil in water coolant
    Mar 2008
    Thank you all 4 ur comments, i fitted the cooler flushed the cooling system most of the oil has gone now.....BUT the cooling warning light comes on now only when driving tho!! the heater blows warm, the engine pipes are hot the temp gauge stays at 90 degrees, all ok except the rad pipes top one is loop warm, the bottom is cold (i replaced thermostat)....the coolant doesnt bubble up and the system doesnt over pressurise any ideas please im desperate now the car is off the road
    Thanks anybody?????
  4. Re: oil in water coolant
    If the cooling system has had a fair bit of oil in it chances are that the thermostat and and switches may need replaced due to contamination.
    You said that you flushed the system did you use a proper cleaner ie one by FORTE /COMMA or similar that is designed to fully clean and flush the system to remove all the oil from the radiator and all the waterways.
    Try that before you panic too much and then add a new genuine thermostat.
    The problem may lso have caused some fault codes to be logged by the ecu (due to spurious readings from contaminated switches )which are setting off the warning lights.
  5. Re: oil in water coolant
    The one you want is Forte Bio Degreaser try www.forteuk.com or www.forteuk.co.uk
  1. T5 2.5 130 water coolant loss and oil light.
    By hocks172 in forum The Commercial Range
    Last Post: 06-10-2010, 07:09 PM
  2. coolant/Water loss every 9-10 days
    By 4lps in forum Passat - B5 Forum - 1997 -2005
    Last Post: 13-10-2008, 12:06 PM
  3. Replies: 1
    Last Post: 18-10-2007, 11:26 PM
  4. 1.9TDi Coolant Water Leak Rear of Engine - Advice Please
    By delta925 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 18-10-2007, 11:23 PM
  5. New - Loosing Coolant water
    By pks68 in forum A8 - S8 - V8
    Last Post: 06-10-2006, 12:39 PM
