Thread: oil in water coolant
Results 1 to 10 of 15
  1. oil in water coolant
    Mar 2008
    audi 1.9tdi 2003 27000 miles just discovered oil in water coolant would be most gateful for any remedys.thought it may be fault on oil cooler but i am complete novice
  2. Re: oil in water coolant
    Hi The oil cooler would be the first thing i would check
  3. Re: oil in water coolant
    Mar 2008
    Quote Originally Posted by kenney View Post
    cheers kenney any ideas on how difficult to change most grateful for any advice cheers nigel
  4. Re: oil in water coolant
    Hi Plain sailing
  5. Re: oil in water coolant
    Jul 2007
    Cheshire, or my A6
    I would have thought that it is more likely to be a cylinder head gasket problem or a cracked cylinder head. I have had this problem on previous cars but not Audis. I can't understand how water would come into contact with the oil cooler.
    Paul
  6. Re: oil in water coolant
    southampton
    I agree with you there paul b, ive had problems with oil in the coolant with previous cars (not Audi) and it has allways been down to the head gasket.
    Failure is not an option, It is a privilege reserved only for those who try.
  7. Re: oil in water coolant
    Quote Originally Posted by paul b View Post
    Paul
    Hi There is always the possibility what you say is true,however the oil cooler has been an issue,and when there is a choice of 2 alternitives then you go for the cheapest first. The oil circulates through the cooler,the oil pressure is greater then the water pressure,oil floats,hence oil in water
  8. Re: oil in water coolant
    I've know of three TDi motors recently with similar problems and all of them were due to failure of the oil cooler
  9. Re: oil in water coolant
    Jul 2007
    Cheshire, or my A6
    I didn't think the oil cooler would come into contact with water. My understanding was that it was air-cooled. However, if it cures it I stand corrected!
    It would be worth checking whether any water pipes are connected to the engine oil cooler, if they don't I highly doubt that the oil cooler is your problem.
    Paul
  10. Re: oil in water coolant
    Hi Paul Yes this has been an issue on many TDI engines,I could never really understand why they call it an oil cooler,when you have water circulating through the cooler with a temp of 90degrees.I remember one job i had (oil in water) took the oil cooler off and pressure tested it,couldnt find anything wrong with it,so we took the head off and replaced the head gasket and in good faith delivered the car thinking we had repaired the fault. A month later the car was back again with the same fault,replaced the oil cooler,which was the culprit.So i said to mysef,never again,as they say once bitten twice shy.
  1. T5 2.5 130 water coolant loss and oil light.
    By hocks172 in forum The Commercial Range
    Last Post: 06-10-2010, 07:09 PM
  2. coolant/Water loss every 9-10 days
    By 4lps in forum Passat - B5 Forum - 1997 -2005
    Last Post: 13-10-2008, 12:06 PM
  3. Replies: 1
    Last Post: 18-10-2007, 11:26 PM
  4. 1.9TDi Coolant Water Leak Rear of Engine - Advice Please
    By delta925 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 18-10-2007, 11:23 PM
  5. New - Loosing Coolant water
    By pks68 in forum A8 - S8 - V8
    Last Post: 06-10-2006, 12:39 PM
