Thread: GOLF Alarm Problem (Interior Monitoring)
  1. GOLF Alarm Problem (Interior Monitoring)
    Feb 2007
    Hopefully someone has come across this prob before.
    My father in law has a Golf GTI which has a problem with the interior monitoring part of the alarm.Basically when you press the button on the pillar next to the drivers seat the LED within the button should illuminate...in this case it isn't.
    I've replaced the button....nil help??????
    Any ideas would be greatly appreciated.
    P.S. The back lighting within the button works as does the function itself i.e interior monitoring turned off,but there is no way of telling as the diode doesn't illuminate.
    '12 Audi A4 Allroad 2.0 TDI 'CGLC'
    '11 VW GOLF BLUEMOTION 1.6 TDI. 'CAYC'
    '07 VW T5 TRANSPORTER T32 ,,,,,, 'BNZ'
    '91 VW GOLF SPORTLINE CABRIOLET 1.8 GTI. 'DX'
  2. Re: GOLF Alarm Problem (Interior Monitoring)
    South Yorkshire
    According to the handbook. The interior monitoring system is switched on at the same time when the anti-theft alarm is activated. To de-activate it as you say you press the button and then lock the door. There is then a note that says that the light in the button will always be on when the vehicle is unlocked. It does not say anything about the light being on when the door is locked and the function dissarmed. It also says that the interior monitoring will automatically reactivate if the vehicle is locked after a door has been opened. So you have to press the button to de-activate the system every time before locking the door.
    "If I hadnt seen such riches I could live with being poor"
    Passat 2.0 Sport DSG 140. 2006
  3. Re: GOLF Alarm Problem (Interior Monitoring)
    Feb 2007
    Totally agree but there is nothing to say that it has been de-activated once button is pressed prior to locking.
    On my Allroad you press the button and the diode illuminates indicating system is disarmed.
    I've checked part no's in Golf & Allroad and both are identical.
    I need somebody to verify that diode illuminates if possible.
  1. interior light flashing when alarm set
    By Lee selwyn in forum Passat - B5 Forum - 1997 -2005
    Last Post: 25-01-2008, 07:55 PM
  2. Golf Mk4 Alarm Problem
    By dunfers in forum Golf MK4 - 1999 - 2004
    Last Post: 29-03-2007, 06:25 PM
  3. 1992 mk 3 golf alarm/immibiliser problem!!!
    By shadowstalker in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 22-01-2007, 04:25 PM
  4. A4 No doors interior lights or alarm
    By diode in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 11-01-2007, 04:34 PM
  5. Golf Alarm Problem
    By PGW in forum Archive posts
    Last Post: 04-01-2007, 09:05 PM
