Thread: front fog light not working
Results 1 to 10 of 11
  1. front fog light not working
    essex
    Today my car has told me my front drivers side fog light doesn't work and i have checked and it is right it doesnt work. i have taken the bulb out and it looks fine but it still doesnt work. Any help fixing will be gratefully accepted.
  2. Re: front fog light not working
    132 Post(s)
    1979 Post(s)
    If it isn't a bulb it could be an on board power supply fault or wiring fault. Have you tested the bulb?
  3. Re: front fog light not working
    essex
    Have tested the bulb after removing from vehicle and the bulb works. connector fits very well. Have put on vehicle and still doesnt work. Any ideas.
    Also is it common for the air mass meter to pack up on these vehicles cos i have been told they do around the 90-100k mark. Is there any other things should look 4.
  4. Re: front fog light not working
    132 Post(s)
    1979 Post(s)
    You need to have a fault code read carried out on the Onboard Power Supply unit. AMM failure is very common; have the engine scanned for codes as well as the OPS unit.
  5. Re: front fog light not working
    essex
    Have had my car scanned for codes and it came up with no faults.
  6. Re: front fog light not working
    132 Post(s)
    1979 Post(s)
    No you need to check the wiring from the on board power supply to the fog light, would you like a wiring diagram?
  7. Re: front fog light not working
    essex
    Yes that would be very helpful. Thank you.
  8. Re: front fog light not working
    132 Post(s)
    1979 Post(s)
    PM me your email and car reg.
  9. Re: front fog light not working
    essex
    have pm'd you with details. thanks
  10. Re: front fog light not working
    essex
    Problem fixed. A very big thanks to crasher for all your help. I traced the wiring from the foglight and found a connector right near to left hand (n/s) fog light wasn't making good connection and so i broke the connection and then refitted it and it has cured the problem. more importantly got rid of the ping noise and the message on the dis.
  1. Climatronic light not working
    By stevo_d01 in forum Golf MK4 - 1999 - 2004
    Last Post: 12-06-2009, 10:49 AM
  2. Mk4 Interior Door Light Not Working
    By HOUCH in forum Archive posts
    Last Post: 30-01-2008, 12:49 AM
  3. 12v socket not working in the front, but is in the boot?
    By sbrowett in forum Golf MK4 - 1999 - 2004
    Last Post: 05-12-2007, 01:40 AM
  4. Luggage compartment light not working
    By makemineamythos in forum Passat - B5 Forum - 1997 -2005
    Last Post: 02-08-2007, 12:48 PM
  5. Front electric windows not working
    By msond in forum 80 - 90
    Last Post: 15-08-2006, 04:00 PM
