Thread: Head gasket
Results 1 to 8 of 8
  1. Head gasket
    Mar 2008
    Hi, i am currently trying to change the head gasket on a mach 2 1990 golf, i have taken all the componts off and the head is free. However the inside cover of the timeing belt is still attached so i cannot fully remove the head. Any suggestions? i have checked throughly and there does not seem to be any more bolts holding it in place.
    Also i managed to slip the cam belt off but am worried when i come to re-fit that i will not be able to ajust the tension?
    your help would be much appreciated.
  2. Re: Head gasket
    134 Post(s)
    2016 Post(s)
    1.3 or 1.6? I think all Golf 2 Match models were 1.3.
  3. Re: Head gasket
    Mar 2008
    yea its a 1.3. Do you have any idea what the problem may be?
  4. Re: Head gasket
    134 Post(s)
    2016 Post(s)
    There is a bolt behind the cam belt sprocket and the sprocket must be removed to allow the head to be removed.
  5. Re: Head gasket
    Mar 2008
    crasher is right.the sprocket has to be removed.
  6. Re: Head gasket
    Mar 2008
    as for timing..if no manual,mark belt against casing before disassembly.if advanced in mechanics mark t.d.c top dead centre on firing order no.1 piston if unsure .....reply
  7. Re: Head gasket
    Andalucia, Spain
    Its a bit of an old thread but I did notice that nobody addressed his point regarding slipping the cam belt off. It should be loosened by turning the water pump - something that must be done sooner or later otherwise you'll never get the bugger back on. And "turn the water pump" means giving it a few clonks with some wood and a hammer as it'll be stuck solid
    Audi - A6 2.6 auto estate
    Other cars:
    Porsche - 911 X50 Turbo / 3.2 Boxtser S
    BMW - E60 M5, E39 M5, E46 328Ci, E38 740 Sport, Z3 2.8i
  8. Re: Head gasket
    134 Post(s)
    2016 Post(s)
    And unless you remove the pump to replace the “O” ring it will leak if you move it.
  1. head gasket
    By Stephenw in forum Golf MK4 - 1999 - 2004
    Last Post: 04-02-2008, 04:56 PM
  2. Help! - Head gasket
    By harveydog in forum Audi A3 - Archive Topics
    Last Post: 10-09-2007, 09:46 PM
  3. 1.8 20V Head gasket
    By CORVR6 in forum Octavia
    Last Post: 02-01-2007, 05:03 PM
  4. Head gasket help please
    By viking power in forum Archive posts
    Last Post: 12-12-2006, 01:10 AM
  5. mk3 1.9 TD Head gasket
    By ckelly0172 in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 05-12-2006, 05:39 PM
