Thread: A3 Temp gage
Results 1 to 10 of 11
  1. Exclamation A3 Temp gage
    Aug 2006
    hey all, i have a 2000 A3 1.8T and the engine temperature gage only works intermittantly. does anybody know what could be the cause of the problem? Is it something i should be worried about? cheers
    Nov 2006
    Oldham, Manchester, UK
    Could be as simple as a faulty sender or a bad connection in the engine bay at the sender unit.
    Maybe one of our more experienced members could make a better suggestion.
    Good luck with it.
  3. Thumbs up
    Aug 2006
    cheers, will check the connections and keep you posted
    Nov 2006
    scotland
    Usual answer is renew coolant temp sensor which sends signal to both guage and ecu.
    Let us know how you get on
    Feb 2004
    Yorkshire
    49 Post(s)
    A very common problem on some VAG's is a "green" 4 pin temp switch, this may be your problem.
    Stuart
    Stuart l VWAudi Forum
    VW Audi Forum - Founder
    Ways to support the website
    Nov 2006
    scotland
    Yep,thats the one.Have changed before on last car -98a4avant(afn)but for over fueling problem. Like you say-common problem
  7. Thumbs up
    Aug 2006
    cool, cheers guys, will check it out and let u know. thanks for the advicce
    Feb 2007
    northeast
    my a4 has been doing it 2 ,took sensor out today and the pins were not clean had corrosion on so cleaned it and put it back on, seems to be ok now
    Mar 2007
    Shropshire
    Quote Originally Posted by yzfr1boy View Post
    I have a 2002 A4 with a tempremental guage. Sometimes its quarter the way up, somtimes at 50, somtimes in the correct position of 90 deg c. Is it safe to detach the sensor plug and have a look. Just curiouse about it upsetting the ECU.
    Many Thanks!
    Apr 2007
    kent
    i usually get me temp gage coming on if the coolant level is low. sound obvious but worth checking if you have a leak somewhere
  1. Temp Gage unstable
    By nigel_07 in forum Audi A3 - Archive Topics
    Last Post: 10-06-2007, 04:59 AM
  2. air-con temp
    By chisel in forum Passat - B5 Forum - 1997 -2005
    Last Post: 21-04-2007, 09:03 PM
  3. radiator/temp gage
    By italianrat182 in forum Audi A3 - Archive Topics
    Last Post: 13-04-2007, 08:22 PM
  4. A4 temp problems
    By plev in forum Audi A4 - Archive Topics
    Last Post: 17-02-2007, 11:34 PM
  5. High Fuel consumption/Strange Fuel gage
    By mkpp786 in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 25-11-2006, 01:53 AM
