Thread: Coming/Leaving home lights
Results 1 to 10 of 18
  1. Coming/Leaving home lights
    Nov 2006
    This is down as an option according to the manual when you lock/unlock your car. Bascially the switch for it is next to the headlight aim control (below the lights switch) which I don't have. Is this possible to retro-fit? Need new control unit and wiring? I think this is different to the auto lights which come on when it gets dark.
  2. Re: Coming/Leaving home lights
    Apr 2007
    Hampshire
    This is something you can turn on using vagcom if you've got it. If not then a friendly local auto-electrician should be able to do this for you. Its come up before on the forum so do a search for more details.
    '53 Smart Roadster Coupe - So much fun, so little cost to run!!
    '03 Kawasaki ZX6R B1H - Currently off the road due to binning it on the M1!
    '02 A4 3.0 Quattro Sport - Gone but missed daily!
  3. Re: Coming/Leaving home lights
    Mar 2008
    I have the same issue as Tony, can someone please post a link regarding this issue
    thanks
  4. Re: Coming/Leaving home lights
    I believe more than just a software settting is required using VAG-COM.
    If the dash switch is set tpo on for this feature, the fog lights do not illuminate on entry or exit if it's light out - only during low light conditions.
    This therefore implies the light sensor is also required, which typically would only be present if the auto lights pack is installed.
    There have been a few good threads on this - one contained a full write up for isntallation including the dimming rear view mirror as part of the same job.
  5. Re: Coming/Leaving home lights
    Mar 2008
    can you please post a link to that thread... thanks
  6. Re: Coming/Leaving home lights
    I may have read this on another site - so excuse the blatant off site link :
    http://www.navplus.us/forums/showthr...ht=coming+home
    There's a few considerations and dependencies to get it working...
  7. Re: Coming/Leaving home lights
    Hampshire
    I was interested in this but it looks a bit too involved for me....and £££ in bits + VAGcom
  8. Re: Coming/Leaving home lights
    I'm North Hants so if you could get to me, I have Vag-Com so could help with the coding if it would make the idea any more viable.
  9. Re: Coming/Leaving home lights
    May 2007
    I've asked this question on the forum before... mycarsavw recommended this site: http://www.autowindow.com/. btw...it's the 'autowindow brite'.
    Havn't got round to ordering it yet.. as don't know of anyone who could fit it..
    My friend has 325Ci and has fitted some kinda 'wiring loom or loop??' ... linked to his interior lights. But now that I have HID's, not too sure if this technique would work as they require a significant charge to get 'em going!
  10. Re: Coming/Leaving home lights
    Nov 2006
    Has anybody managed to do this? According to this thread in the B7 forum:
    https://www.vwaudiforum.co.uk/forum/s...ad.php?t=46888
    you can install the coming home/parking feature without any auto-dimming mirrors but you do need to put a wire across pins to fool the system that you have the auto light switch. After that its vag-com coding. If it can be done for a A3, then I don't see why not for a A4.
  1. Hazard lights coming on when indicating
    By Dex2034 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 25-09-2008, 02:26 PM
  2. Engine cut outs, warning lights coming on!
    By barnaby82 in forum Archive posts
    Last Post: 04-02-2008, 07:59 PM
  3. random warning lights coming on..and getting worse!!
    By jonnycool in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 16-10-2007, 05:25 AM
  4. Automatic Headlights with coming home /leaving home facility
    By TonyS in forum Chat - Anything with wheels
    Last Post: 25-06-2007, 03:44 PM
  5. Rear Brake lights coming on during the night!
    By milesyboy76 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 19-04-2007, 12:06 AM
