Thread: Big Bang & Lots Of Black Smoke. Help Needed!
Page 3 of 3 FirstFirst 123
Results 21 to 30 of 30
  1. Re: Big Bang & Lots Of Black Smoke. Help Needed!
    #21
    sheffield on sea
    ok there was a bit of oil dribbled out of the pipe, what causes oil in the intercooler pipes,is it normal or is my intercooler about to spectacularly explode in a shower of sparks and smoke.
  2. Re: Big Bang & Lots Of Black Smoke. Help Needed!
    #22
    135 Post(s)
    2041 Post(s)
    That is from the turbo and the crankcase ventilation system, is perfectly normal and nothing to worry about.
  3. Re: Big Bang & Lots Of Black Smoke. Help Needed!
    #23
    Quote Originally Posted by Nutty View Post
    What youve just described is a pipe being blown off on the charged air side of the inlet track
    ive just had the same problem but dont know where to look do you need to take the cover off under the engine?
  4. Re: Big Bang & Lots Of Black Smoke. Help Needed!
    #24
    135 Post(s)
    2041 Post(s)
    Salad, what car?
  5. Re: Big Bang & Lots Of Black Smoke. Help Needed!
    #25
    golf gt tdi 150 soz
  6. Re: Big Bang & Lots Of Black Smoke. Help Needed!
    #26
    135 Post(s)
    2041 Post(s)
    That will be the pipe to the intercooler, the metal barbs will have worn away and you will need a new pipe 1J0 145 834 AA at £51.32. This is very difficult to get at without raising the car up.
  7. Re: Big Bang & Lots Of Black Smoke. Help Needed!
    #27
    Dec 2007
    New Mills, Derbyshire
    ??? Is that normal on the 150 tdi too? My oily smoke problem seems to have cleared itself up, but Ive got a replacement £££ turbo awaiting fitting next week. I can sent it back to VW if a bit of oil in my intercooler is normal as the oil seals on my turbo may well be OK???
    150 GTI DIESEL - propper juice!!
  8. Re: Big Bang & Lots Of Black Smoke. Help Needed!
    #28
    135 Post(s)
    2041 Post(s)
    I have seen six month old 12K mile cars with oil dripping off the turbo connections; the Fabia VRS even has a hole in the lower liner at the intercooler lower connection to let the oil drip onto the floor.
  9. Re: Big Bang & Lots Of Black Smoke. Help Needed!
    #29
    sorry if i sound thick but where abouts do i need to look i can get use of a garage with a pit or will it be obvious from underneath?
  10. Re: Big Bang & Lots Of Black Smoke. Help Needed!
    #30
    found it m8 cheers for your help
  1. sharan 130 tdi pre heater fault - lots of smoke
    By paulwebsterthompson in forum Touran - Sharan - Caravelle
    Last Post: 20-07-2011, 01:12 PM
  2. passat 1996 lots off smoke when started
    By jill300268 in forum Early Passat Forum - Pre 97
    Last Post: 16-01-2008, 12:31 AM
  3. No Power, lots of smoke
    By makil6 in forum Archive posts
    Last Post: 15-01-2008, 07:00 PM
  4. a4 black smoke
    By nickcon16 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 01-11-2007, 07:18 PM
  5. lots of smoke from auxiliary exhaust
    By gwdel1 in forum Touran - Sharan - Caravelle
    Last Post: 27-10-2007, 03:35 PM
