Thread: t4 coolant loss
  1. t4 coolant loss
    1900 t4 R reg was loosing coolant very intermitant seemed to be boiling out of the expantion tank, would go a few miles and loose a litre or go a hundred miles and loose nothing, seemed to loose more as it was warming up. Pressure tested system, gas test, then renewed thermostat and water pump. It is still loosing. Any ideas?
  2. Re: t4 coolant loss
    May 2007
    check the rubber hoses as i've had a similar fault which took ages to sort as months went by a hose split in the cold weather then it really lost a lot of water
  1. A4 Coolant loss
    By leej in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 17-07-2010, 07:58 PM
  2. GT TDI 115 Coolant Loss
    By jordelver in forum Golf MK4 - 1999 - 2004
    Last Post: 30-08-2009, 09:03 PM
  3. coolant loss
    By jess james in forum The Commercial Range
    Last Post: 11-01-2008, 06:00 PM
  4. Coolant loss?
    By daveac41 in forum Polo - Derby - Lupo - Fox
    Last Post: 11-11-2007, 03:22 PM
  5. Coolant Loss
    By benGT in forum Golf MK4 - 1999 - 2004
    Last Post: 10-01-2007, 10:11 PM
