Thread: Engine / Gear oil leak
  1. Exclamation Engine / Gear oil leak
    Herford, Germany
    The mechanics tell me it is pretty serious. How serious is it?
    My car is a rusty 1989 Mark II
    How much to have fixed realistically?
  2. Re: Engine / Gear oil leak
    Herford, Germany
    New development - the gearbox has become amazingly difficult to work tonight.
    Loud clanking sounds are the norm however the higher gears are much easier to use.
    The last time this happened the mech looked under the car and found a screw / bolt / shaft had come undone. Does anyone have any idea what this is?
  3. Re: Engine / Gear oil leak
    Mar 2008
    can you be more specific i.e temperature,oil level dipstick,tailgate exhaust
  4. Re: Engine / Gear oil leak
    Herford, Germany
    Quote Originally Posted by monza73 View Post
    The exhaust was working fine, temp does not seem outof the ordinary, oil was a little low when I got the car but nothing to write home about and I topped up accordingly.
    The mechanics have identified the problem I think. A bolt connecting the gearbox to a crankshaft has come loose. It has happened twice now.
  5. Cool Re: Engine / Gear oil leak
    Herford, Germany
    It seems ATU have found the problem. I have a broken part that requires replacing but they cannot supply it. I must go to VW direct.
    The part is used underneath my vehicle / engine and when you change gear a small piston moves back and forth. Well the rod / piston is not staying inside the part.
    Apparently it costs aboy £50 and then fitting.
    I could take a picture if anyone wants to help
  1. engine water leak
    By johno1 in forum Passat - Archive Topics
    Last Post: 14-02-2008, 12:13 AM
  2. Passat Engine Swap/Oil Leak?
    By kieren12345 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 26-08-2007, 08:27 PM
  3. Bad oil leak at rear of engine
    By carlo in forum Early Passat Forum - Pre 97
    Last Post: 19-08-2007, 09:17 AM
  4. Footwell water leak / first gear is stiff
    By stejuk in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 02-06-2007, 11:03 PM
  5. Engine oil leak
    By tel7448 in forum Passat - Archive Topics
    Last Post: 01-04-2007, 10:30 AM
