Thread: 2.4 V6 AGA engine water / oil temperature
  1. 2.4 V6 AGA engine water / oil temperature
    May 2007
    Would like to know what readings people are getting on there guages for this engine.
    Mine gets to 75 - 80 on days where air temperature is 12 degrees
    On frosty days say 4 degrees the water temperature hardly moves.
    Convinced I need to change the thermostat rather than the sensor, which is a sod of a job so just looking for info from other drivers of similar vehicles before I bite the bullet.
    will probably end up changing water pump and belt is got to strip the engine down that far.
  2. Re: 2.4 V6 AGA engine water / oil temperature
    Mar 2007
    Yorkshire
    Quote Originally Posted by lonky View Post
    Mine used to run at 90 whatever the weather was doing i.e. straight up at 12.00 o'clock.
    If you remove the pipe from the front of the header tank, (at the top) it should pump water out when the thermostat is open. If it does this when the engine is cold, then the thermostat is jammed open, or so I am told.
    The thermostat opens at 84 on mine
    2007 Audi A6 3.0 TDi quattro S line manual saloon
    1975 Rover P6 4000S 5 speed
    Time flies like an arrow
    Fruit flies like a banana
  1. engine temperature
    By Parky in forum Audi A3 - Archive Topics
    Last Post: 24-01-2008, 10:14 PM
  2. Engine Temperature Sensor Replacement
    By AndyV5 in forum Golf MK4 - 1999 - 2004
    Last Post: 17-10-2007, 10:11 PM
  3. 2.5 TDI engine temperature
    By tut_gareth in forum Audi A6 - C4 Forum - 1994 - 1997
    Last Post: 14-08-2007, 08:06 AM
  4. Water Temperature Indicator
    By padrag_king in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 22-07-2007, 05:27 AM
  5. WATER TEMPERATURE SENDER
    By taff in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 30-11-2006, 06:30 PM
