Thread: TDC position confirmation
  1. Question TDC position confirmation
    Bern, Switzerland
    After pulling everything off to check the CAM setting on the timing belt I faced a bit of a dilema.
    Hopefully someone can help, where is TDC on a VW Sharan 1.9 TDII 1999 with an AFN engine and Automatic gearbox. I am going to assume that left hand drive will make no difference to TDC but then I could be wrong ...
    Enclosed are three possible positions but which is it ????
    Haynes on the Ford says at the bottom but has a different shaped window and it isn't for a VW .. The VW manual shows a different hole, for a manual gearbox I think.
    In the past the manufacturer normally sees fit to put a point or arrow so there is no doubt ....
    Thanks in advance or am I being really stupid here and missing something (wrong window onto it, etc ???? )
    Ignore the feathers, a bird decided to help assist me whilst at speed .. grin ..
  2. Re: TDC position confirmation
    Hi The picture in the middel is correct
  3. Re: TDC position confirmation
    Bern, Switzerland
    Thanks for the reply, that is the one I had expected it to be, however the cam lined up on the last one ... 8-(
    When I put the injector lock pin in it didn't fit well, it was much easier to put in and out when set to the middle picture.
    No wonder it runs like a bus and drives like a hippo ...
    I guess I am off to reset the CAM ... cheers !!
  1. Temp sender position
    By jon h in forum Archive posts
    Last Post: 02-01-2008, 11:06 PM
  2. throttle position sensor?
    By lee07 in forum Golf MK4 - 1999 - 2004
    Last Post: 15-10-2007, 06:07 PM
  3. Head Unit Position?
    By coeur in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 04-08-2007, 09:58 PM
  4. Replies: 2
    Last Post: 04-04-2007, 02:20 PM
  5. Cam Position Sensor
    By zenmaster in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 24-02-2007, 10:57 AM
