Thread: T4 2.0 Starting problem
  1. T4 2.0 Starting problem
    Hi everyone,
    I just got my T4 2.0 back from the garage due to a loss of coolant. Problem was apparently thermostat housing leaking.
    Now that s fine, except since the car came back from the garage I am having problem when starting on cold engine. Engine will start after one or two times but if I accelerate the engine goes wild and RPMs go up and down. in other words engine won t acccelerate in a linear fashion. The problem seems to stop once the engine is warm after a couple minutes
    Any idea ?
    Before going changing the thermostat housing never had such issues
    Car has around 200,000km, new belts and water pump
    thanks for your help
    antoine
  2. Re: T4 2.0 Starting problem
    Gloucesterhire
    Straight back to the garage with it m8.
    If the problem has been created by the repair get them to sort it.
    Jeff
    T5 LWB 2007 102 Transporter Imapped to 135ps,running 9j Mugello alloys & low profiles.
  3. Re: T4 2.0 Starting problem
    northants
    disconnect battery for a while and the brain may reset itself and sort it out.I've been told it's best to leave it disconnected for a few hours. This may just be a load of rubbish, i'm no expert. Worth trying though.
  1. A6 Starting Problem
    By shugielog in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 26-09-2008, 11:01 PM
  2. 98 Mk3 GSX cut out and starting problem
    By ruler_70 in forum Golf MK3 - 1993 - 1999
    Last Post: 14-11-2007, 08:26 PM
  3. starting problem
    By bilal aslam in forum Touran - Sharan - Caravelle
    Last Post: 24-02-2007, 08:51 PM
  4. A3 Starting problem
    By Pixie in forum Audi A3 - Archive Topics
    Last Post: 04-02-2007, 04:23 PM
  5. TDI starting problem
    By j_coupland in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 30-08-2006, 11:46 AM
