Thread: HEATED SEATS NOT WORKING
  1. Cool HEATED SEATS NOT WORKING
    Nov 2006
    little sutton
    IVE GOT A GOLF 1.6 SE T REG FOR THE WIFE, AND ITS GOT A PROBLEM WITH FRONT HEATED SEATS,THE DRIVERS SIDE WAS WORKING UNTILL I SWAPPED THE HEATER CONTROLS OVER TO SEE IF THE PASSENGER SIDE CONTROL WAS FAULTY,NOW NONE OF THE SEATS ARE WORKING AND IM IN THE DOG HOUSES WITH THE WIFE ,IVE CHECKED THE FUSE WHICH IS OK.HAS ANYONE GOT ANY IDEAS
    May 2006
    Have you checked you have reseated all connections properly? Try removing the battery and try them again. Also, I read on another forum that someone with a imilar problem happened to replace their battery (which was a bit old and tired) at the same time they were trying to fix their heated seats. With the new battery on, they worked spot on. All to do with the amount of current which is drawn apparently. So if you have an old battery, that might be the cause
    Nov 2006
    little sutton
    THANKS I WILL CHECK THE CONNECTIONS UNDER THE SEAT,IVE TRIED DISSCONNECTING THE BATTERY BUT NO JOY.IT MIGHT BE WORTH ME GETTING THE BATTERY CHECKED OUT.I THINK HALFORDS DO A FREE CHECK.THANKS FOR YOUR HELP.I WILL LET YOU KNOW HOW I GET ON
  1. Replace Seats In Audi A4 1.8t Se With Seats From S4
    By MARVELLOUS in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 02-02-2008, 06:38 PM
  2. A3 Seats
    By nfh288gto in forum Audi A3 - Archive Topics
    Last Post: 19-11-2007, 04:43 PM
  3. Retro fit heated seats?
    By carl s in forum Passat - Archive Topics
    Last Post: 03-03-2007, 10:59 AM
  4. heated seats
    By sharpies in forum Passat - Archive Topics
    Last Post: 12-02-2007, 11:56 AM
  5. HEATED SEAT not working
    By babaroga in forum Passat - Archive Topics
    Last Post: 30-03-2006, 10:58 PM
