Thread: Clutch Change and a lucky escape
  1. Clutch Change and a lucky escape
    Frazzly Guest
    Hey guys,
    Picked my Avant t sport up last week and drove 400 miles to find the clutch starting to slip. Great fun!!
    Anyway got a LUK clutch kit from gsf for £96 pus vat and had a busy day fitting it. Wont do another in a hurry but glad its done. It had burned right down to the rivets in the pressure plate side ( And the Dual mass flywheel seemed in good condition).
    BUT as I was having a nosey around I noticed the timing belt was very badly cracked. Weird, the history shows it isn;t due a another belt for 10k. Very glad I checked it and changed it. Once the bumper is off its a very easy job. I managed to do it without dropping the coolant too!
    Anyway I was too busy to take pics but if anyone wants any info on what I did feel free to reply. Also next time the bonnets up peer behind the timing belt cover and get a look at that timing belt!! Ill look abit harder next time I buy a car!
    Lol
    Fraz
  2. Re: Clutch Change and a lucky escape
    hi, i have a 1.9tdi toledo same engine as the audi, question is do you need to remove the frout bumber for to change the timing belt or can you get away with it.
    thanks in advance
    Gerry
  3. Re: Clutch Change and a lucky escape
    Frazzly Guest
    Yes, bumper and front panel had to come forward. I cheekily left the rad connected and still had plenty of space..
  4. Re: Clutch Change and a lucky escape
    Byrnt Guest
    Hey thanks for this post. I just had my engine replaced today and they are going to do the timing belt now that it is back in. the front is off, so I think they are about ready to go. When you say it was quick to do, how quick was it, as I would love to get the car back tomorrow if possible. Can you fit any timing belt to these engines or is there a "special", audi one. My car is a 1.9tdi.
  5. Re: Clutch Change and a lucky escape
    Frazzly Guest
    If they charge more than an hour then they are robbing you. MAKE SURE THEY REPLACE THE TENSIONER TOO! The kit I first got didn;t have a tensioner, just a pulley. ITS IMPERATIVE THEY REPLACE THE TENSIONER!
  6. Re: Clutch Change and a lucky escape
    Byrnt Guest
    ok and does the waterpump need to be replaced as well? So how long does it take to put the front back on, also I wonder if you know how long it should take to replace, ball joint, anti roll bar links, track rod arm, track rod end, cv boot one passenger side?
  7. Re: Clutch Change and a lucky escape
    Cheshire, or my A6
    Quote Originally Posted by Byrnt View Post
    Yes, the waterpump needs replacing. Audi gave me some money back if I returned to the old one. However, my A6's front would not move forward, so I did take the bumper etc off. You can run a search on the forum and search for "my A6 timing belt experience" and you'll see what I had to do.
    Paul
  1. Clutch Change 1.4 8v
    By Gunzi in forum Polo - Derby - Lupo - Fox
    Last Post: 10-11-2007, 01:15 PM
  2. How to escape a fart!!
    By dessimpson in forum Chat - Completely Off Topic
    Last Post: 26-06-2007, 10:56 PM
  3. One V.lucky B5 Owner
    By new to vw in forum Passat - B5 Forum - 1997 -2005
    Last Post: 03-05-2007, 04:21 PM
  4. Clutch change......caveat emptor
    By Gaz the Cab in forum Passat - Archive Topics
    Last Post: 13-01-2007, 07:38 PM
  5. Clutch change Golf Mk III 1.8
    By brianf in forum Golf MK3 - 1993 - 1999
    Last Post: 04-01-2007, 04:23 PM
