Thread: Remote Central Locking
Results 1 to 10 of 15
  1. Remote Central Locking
    Nov 2006
    Hi all,
    I have just joined the forum and hope someone will be able to help me!!!
    I own a 1998 1.6 SE mark IV Golf, recently the remote locking has stopped working, I took it to my local VW dealer and they said it just needs a new battery.
    They changed it, re-syncd it and nothing!!!
    All they could recommend is that I book in for a few hours diagnostic, at £90+VAT and hour its goign to be expensive.
    After some tinkering, it looks like my passnger door lock is busted as well, not sure how long this has been broken. This would explain why that door along with the boot doesn't open when I unlock the doors with the key in the drivers lock (I've only got 1 key!!).
    Can anyone advise on a solution? Is it a case of just a new lock in the passenger door or is it a case of a new central locking sytem or ECU?
    Thanks, looking forward to reading your replies!
    Ricc
    Oct 2005
    You say in another of your posts that you're not at all mechanically inclined so bear that in mind before tackling anything.
    The solder joints in the doors of VWs are notoriously bad for breaking. Check the wires (in the rubber sleeves) in the door jambs first for any signs wear.
    What, if anything, happens when you press the unlock button on the key fob?
    Do you have any diagnostic codes you can share with us?
    Is there any water damage to the carpets?
    What happens when you place the key in the driver's door lock and turn it to open, do all the doors/boot open, do the indicators flash?
    If you hold the key in the open position do your windows roll down?
    Given time (more than say one day!), those with the answers will reply. Not everyone has the time to be online waiting for questions to be asked.
    Welcome to the club.
  3. Question Remote Central Locking
    mbertouche Guest
    It may sound a bit simple but have you tried a new battery in your 'zapper?'
    I also have a 1996 Passat CL TDI and have found that the boot lock needs to be in a certain position before it will unlock with the doors. I think it is a security feature.
    Mike
    Nov 2006
    Oldham, Manchester, UK
    Quote Originally Posted by the_italian_job View Post
    Yup, I think he tried that one.
    hi this is my first post here.
    i have a similar problem to the original poster on my Seat Ibiza. the battery in the keyfob went flat which i have now replaced but now it seems the car has gone deaf! i assume i just need to resync the keyfob to the car but i am at a loss how to do it. its a '99 T reg seat ibiza i would appreciate any suggestions
    london/ UK
    Quote Originally Posted by cooperjinx View Post
    Put the key in the drivers lock and lock the car with the key, then immediatelly press the open button on the remote. Its as simple as that ! Its all explained in the owner manual ...if someone bothers to read the book !?! Repeat if unsuccesfull. hope this helps.
    thanks for the quick reply and the help. unfortunately the method you described didnt work is there any other way?
    do you have a full version of vagcom? because that can do it in a matter of seconds.
    no idea what that is so i guess the answer is no
    anyway ill give adams method another try when i get home as im at work right now and dont have much time to mess around with it
    Apr 2007
    Lancashire
    Have you tried clearing all the stored keys before re-synching your key?
  1. Problems with remote for central locking?
    By A4 Kim in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 18-01-2009, 12:42 AM
  2. Remote central locking problem
    By ImolaOrange in forum Passat - B5 Forum - 1997 -2005
    Last Post: 01-06-2007, 03:05 PM
  3. Remote Central locking, any ideas ?
    By waylonbuddy in forum Passat - B5 Forum - 1997 -2005
    Last Post: 21-04-2007, 07:19 PM
  4. Help with remote central locking please
    By sf01 in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 14-02-2007, 12:35 AM
  5. Remote central locking
    By dazza in forum Passat - Archive Topics
    Last Post: 31-12-2006, 04:11 PM
