Thread: Mk3 Golf GTi 16v 1996 (P)
  1. Question Mk3 Golf GTi 16v 1996 (P)
    Nov 2006
    Milton Keynes
    I have a Mk3 16v GTi, 1996 import model - ie no air bags, manual windows, and I have 2 problems with the car;
    Intermittent cutting out, usually when I'm coming to a stop at a roundabout. It usually happens when the car has been at a constant speed, ie coming off the duel carriageway on the way to / from work, coming off a motorway etc. The car has got a full service history and has done 88k, last service being October 2006.
    Yesterday, the orange warning light on the dash came on, the one situated next to the red oil warning light. What is this warning me about?
    Can anyone tell me what either of these problems are?
    The cutting out could be caused by the stablizer valve. It is located in front of the intake plenium. It has a electric plug on one end and a breather hose going to it and out again at right angles. If you take it off and clean it out with something like carb cleaner. I always gave mine a squirt of plus gas before putting it back.
    What symbol is on the orange light?
    Regards Boardboy.
    Nov 2006
    Milton Keynes
    Quote Originally Posted by Boardboy View Post
    Regards Boardboy.
    Hi Boardboy thanks for the info on the cutting out problem, I will give it a try at the weekend. As for the orange light, it has a circle and a broken circle on the outer sides of the circle. there is no symbol inside the circle. It is located next to the brake symbol - not the oil warning light as i said previously. I have checked the handbook for this symbol and cannot find it in there either.
    JLX45V
  4. Brake wear warning light
    jlx45v -The orange light with the broken circle outside another circle is the brake pad wear warning light.
    You need to have a look at the brake pads. I don't know how mechanically minded you are but it's not to bad a job.
    Regards Boardboy
    Nov 2006
    fife
    Quote Originally Posted by jlx45v View Post
    i`m maybe wrong about this,but, i had the cutting out problem with my mk3 anniversary at junctions and roundabouts.the dealer could not find any fault code,but cleaned out the throttle bodies and were as good as new.problem solved.they took 1/2 an hour to do it and was only £ 80.00.
    maybe worth a shot!
    p.s if i`m wrong,it was my brother that wrote this reply!!!!!
  1. Mk3 Golf Tdi (1996) acceleration problem
    By Octavius in forum Golf MK3 - 1993 - 1999
    Last Post: 28-03-2007, 05:50 PM
  2. 1996 Golf Mk3 1.6 cambelt AEE
    By lukegal in forum Golf MK3 - 1993 - 1999
    Last Post: 23-01-2007, 09:26 PM
  3. 1996 - Golf TDi - Heater Problems
    By Octavius in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 25-10-2006, 08:42 AM
  4. 1996 Mk3 Golf GTI 16v - Itermittent Fault
    By Willsjunk in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 16-07-2006, 09:49 PM
  5. Which Immobilizer on 1996 Golf and corresponding key ??
    By vr6hp in forum Golf MK3 - 1993 - 1999
    Last Post: 08-02-2005, 04:06 PM
