Thread: Diesel filter air leak/lock? o-ring?
  1. Diesel filter air leak/lock? o-ring?
    Is there supposed to be an o-ring (see photo), present in the output assembly from the diesel filter housing (T4 2,4d 2000)? I can't help but think that there must be! Have bled air from system and topped up filter several times with no result. Filter resize w arrow.jpg
  2. Re: Diesel filter air leak/lock? o-ring?
    birkenhead ,wirral ,uk
    hi the o-ring should be on the plastic bit that sits in, then is locked up with clip,,, i bought a filter and the plastic bit wouldnt sit in properly.
    so i took it back to euro-parts and they give me a golf filter, a smaller filter, but all fitted up ok ,and is still working fine...
    hope this helps
    cheers willy
  3. Re: Diesel filter air leak/lock? o-ring?
    Hi No, there should be no o ring there you have pointed to,on the other hand the o ring is on the plastic connection,and if these leak the system will draw in air,and fail to start.
  4. Re: Diesel filter air leak/lock? o-ring?
    forgot to mention , i connected the 2 pipes together,without plastic bit while i got a replacement new filter, just bunged hole with a bolt, sounds mad but i knew, that the plastic bit wasnt sitting properly,could see it fizzing ... check plastic bit for flat o-ring and check that it sits snug in hole...or get a golf filter i know they fit
  1. Pollen filter leak fault
    By dazwalker in forum Passat - B5 Forum - 1997 -2005
    Last Post: 18-01-2008, 10:51 PM
  2. Pollen filter water leak
    By cuffbert in forum Golf MK3 - 1993 - 1999
    Last Post: 15-01-2008, 08:30 PM
  3. Fuel filter leak...
    By sherlockuk in forum Passat - B5 Forum - 1997 -2005
    Last Post: 16-08-2007, 09:09 PM
  4. Pollen Filter leak - Easy fix....
    By SammyP in forum Passat - Archive Topics
    Last Post: 13-03-2007, 06:12 PM
  5. Pollen filter seal - water leak
    By Mav2006 in forum Passat - Archive Topics
    Last Post: 28-02-2007, 05:43 PM
