Thread: audi a3 door card
  1. audi a3 door card
    Oct 2006
    hi can anyone help i want to change speakers in front door and pillar in a3 2004 mole but dont want to damage any one know how this is done
    ????? remove the door card i mean and any other advise would be welcoming
    thanks
    I can give the instructions for a 2002 A3. I can't imagine they are that much differant.
    The door pull molding inside the car there is a screw. Remove this (it's at the back). Pull the molding down and it will come out.
    You should be able to see two screws now where the moulding was. Remove the screws. Then remove the screws at the front and back top corners of the door trim.
    Lift the trim panel, unhook it, and withdraw it alittle way from the door. Pull back the foam seal, then unclip the interior door handle outer cable from it's clip. The inner end of the cable has a hook on it. Unhook this from the fitting (NOTE: The way the hook is. It should be hook facing up) Disconnect the window, mirror and courtesy light plugs. That should be it.
    I got to say it's easier with pictures so buying a manual might be a better option.
    Anyway good luck and hope this helps.
    Regards Boardboy
  1. audi a4 door card removal
    By ratbag73 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 29-04-2016, 04:37 PM
  2. Door Card/Trim Removal
    By KEVMAC in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 13-12-2007, 06:50 AM
  3. door card removal
    By squinty in forum Audi A3 - Archive Topics
    Last Post: 10-06-2007, 05:03 PM
  4. Drivers door card on '01 Bora
    By Dermo123 in forum Bora - 1998 - 2005
    Last Post: 10-01-2007, 02:52 AM
  5. DOOR CARD
    By GARY in forum Archive posts
    Last Post: 29-12-2006, 08:51 PM
