Thread: VAG Tacho 2.2 help required - Audi TT
Results 1 to 10 of 11
  1. VAG Tacho 2.2 help required - Audi TT
    Dec 2007
    Hi Guys,
    I have an Audi TT (2002). I just used VAG Tacho 2.2 to reset the mileage. Everything seemed to have been entered correctly but once i disconnected the battery and connected it again the milegae now reads 999999. Even after driving it the mileage stays at 999999.
    Any ideas how I can fix this?
  2. Re: VAG Tacho 2.2 help required - Audi TT
    assuming you got the legitimate version, you would have had to change the mileage display to KM via vagcom before correcting.
    VT works using Kilometres as the unit of distance, UK default is of course, miles.
    you need to alter this using vagcom, so that the mileage is KM instead of M.
    once done, correct the mileage with VT, close.
    then go back into Vagcom and put the display back to M from KM.
    HTH
  3. Re: VAG Tacho 2.2 help required - Audi TT
    Dec 2007
    Thanks for your response.
    I will try this later tonight.
    How do I change the display to read KM instead of Miles using VagCom?
  4. Re: VAG Tacho 2.2 help required - Audi TT
    Quote Originally Posted by apowar View Post
    im not sure if it's available on the shareware version, but try ross-tech.com or their wiki...
  5. Re: VAG Tacho 2.2 help required - Audi TT
    Dec 2007
    cool. will have a look.
    Is Vag Tacho and Vag com the same? Can I use the same cable for both?
  6. Re: VAG Tacho 2.2 help required - Audi TT
    Mar 2008
    I have the same problem with my audi tt. I was trying to correct the mileage with a vag tacho cable 2.2, but after that the display is showing 999999999 and the unit is changed to km. Could you write me the process to change to miles again my car using the vag com cable?
    thank you so much for your help,
    henry
    Quote Originally Posted by eshrules View Post
  7. Re: VAG Tacho 2.2 help required - Audi TT
    Magdeburg, Germany
    Grats, that's what you get from messing with your mileage. If you bought the legitimate version of VAG-Tacho then you should contact the developer/seller for help. If you bought the illegal copy, well you already got what you paid for. LOL
    Sebastian @ www.Ross-Tech.com
  8. Re: VAG Tacho 2.2 help required - Audi TT
    Feb 2004
    Yorkshire
    49 Post(s)
    Please be aware that this site does not allow the discussion of illegal copies of software of this nature.
    Unless this was purchased from the "official" owner of the software, then please do not discuss this any further.
    Further discussion will result in this post being closed, or removed.
    Stuart l VWAudi Forum
    VW Audi Forum - Founder
    Ways to support the website
  9. Re: VAG Tacho 2.2 help required - Audi TT
    Vagtacho will only change the bytes that respresent the mileage, it does not correct the checksum.
    Your cluster has detected a bad checksum and hence displays 99999999.....
  10. Re: VAG Tacho 2.2 help required - Audi TT
    Did you ever resolve your problems with the correction?
  1. Replies: 0
    Last Post: 15-12-2007, 04:37 PM
  2. Are And Vag Com / Vag Tacho The Same
    By davecoz in forum VCDS - General Questions
    Last Post: 21-11-2007, 09:13 AM
  3. Audi Cabriolet 1996 2.0E workshop manual required!
    By John Griffiths in forum 80 - 90
    Last Post: 16-05-2007, 01:39 PM
  4. Audi 80 B3 1.8 Gearbox, Help Required
    By Knightkiller in forum 80 - 90
    Last Post: 04-02-2007, 03:42 PM
  5. Audi 80 Advant - Help required!
    By diamondbrit73 in forum 80 - 90
    Last Post: 18-01-2007, 11:41 PM
