Thread: Washer jets.
Results 1 to 10 of 10
  1. Washer jets.
    Aug 2007
    Chatham, Kent.
    I'm at my wits end with these washer jets, i cleaned them out with a pin last week and all 4 are blocked again, i tried to remove the drivers one but was worried about snapping it, also it has an electric cable going into it, can i assume its heated?? Is there a way of removing these to clean them?? Or alternatively where can i sorce some new ones?? Car is a L reg a80 se sport.
    Thanks, Phil.
  2. Re: Washer jets.
    Jan 2008
    hi there - just an idea - i had this before on a couple of cars!
    i usually find pumping liquid or air the opposite way does the trick!
    prefered tool for me is a small syringe with a small bit of pipe!
    its fiddly keeping a seal over the holes but you usually dont need a complete seal - just as long as some pressure goes through - dont forget to disconnect the pipe somewhere easy to see what comes out!
    its not technical but normally does the trick for me!
    you have probably got some loose dirt in the tank and it might happen again?
    good luck what ever you sort out
  3. Re: Washer jets.
    Sep 2007
    North Wales
    Thanks for that, Andy, as I am having hellish problems with my drivers side washer jets too. I'd never thought of "reverse flushing" them!
  4. Re: Washer jets.
    Aug 2007
    Chatham, Kent.
    I'm pretty sure now its the hard water in this area, its full of chalk judging by the state of our kettle! Still reakon their heated 'cause they have wires going into them.
  5. Re: Washer jets .
    Mar 2008
    Calgary Canada
    Just got my 90 q 20v from Japan . The washers worked fine until driving thru the mountains on my way home to Calgary Canada from Vancouver. They stopped working when I put fluid in both tanks and it slowly ends up on the ground . Since then they worked once (my surprise) and not since. The pump hums away like crazy but no spray. I don;t even have an owners manual. Is it possible it;s related to this clogging problem I read about on this thread. Any ideas on this one
    Thanks Johnny Canuck
  6. Re: Washer jets.
    Mar 2008
    Quote Originally Posted by Millerman View Post
    The wires are for heating the jets.
    You can insert a screwdriver to release the tab which holds the jet in place from under the bonnet.
    They are still very difficult to remove and you'll think the bonnet is going to bend with the force needed.
    1991 90 quattro 20v sport
    1987 Coupe quattro
    1988 quattro
  7. Re: Washer jets.
    Aug 2007
    Chatham, Kent.
    Thanks Mike, had an idea they was heated, now i just gotta get the bugger out of the bonnet
  8. Re: Washer jets.
    Mar 2008
    Quote Originally Posted by Coastie View Post
    Have heard of the same problem.
  9. Re: Washer jets.
    Mar 2008
    If you're not getting much fluid coming through, it's possibly the pump itself.
    I changed the pump on my 90 20v and it made a huge difference
    1987 Coupe quattro
    1988 quattro
  10. Re: Washer jets.
    Aug 2007
    Chatham, Kent.
    Mike, its defo the washer jets fella, i've had the hose off the back of the jets and it pumps out fine and strong.
  1. Heated Washer Jets for Windscreen
    By Polo Mint in forum Polo - Derby - Lupo - Fox
    Last Post: 21-02-2008, 05:12 PM
  2. Heated washer jets - Seasonal Topic!
    By TDi_B5 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 23-12-2007, 05:35 PM
  3. Heated washer jets not working.
    By BenR in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 22-12-2007, 11:18 AM
  4. Heated windscreen washer jets?
    By Zub in forum Passat - Archive Topics
    Last Post: 02-03-2007, 04:55 PM
  5. "Spray" front washer jets
    By Celtic Cousin in forum Audi A4 - Archive Topics
    Last Post: 23-12-2006, 05:10 PM
