Thread: MAF oppinions
Results 1 to 10 of 11
  1. MAF oppinions
    Runcorn,Cheshire
    Hi, recently run vag com measure blocks to check the maf and on 3 runs got a reading of 108g/s in 2nd gear on each run,my reading should be 120 g/s according to ross-tech fuel trim write up but does say if the reading is significantly lower it could be a maf problem but is 108 g/s signifficantly lower than 120 g/s ?
    Thanks in advance
    Davec
  2. Re: MAF oppinions
    May 2007
    Leeds
    Does it say to run in second on the site?
    Do a full throttle run in third and post the logs so we can see.
    Paul
  3. Re: MAF oppinions
    As above, IIRC, Rosstech states to run in 4th, the general idea being to run the car in high a gear as possible.
    3rd or 4th gear are ideal.
    get it on the motorway where it is safe to do such speeds, with a friend on the passenger seat, monitoring the logs etc and report your findings back here, or even better, a screendump of the actual graph would be useful.
  4. Re: MAF oppinions
    Runcorn,Cheshire
    Quote Originally Posted by RSTuning View Post
    Paul
    Yes,i followed this taken from ross-tech web site
    Here's a good sanity check for the status of your MAF. Do a full-throttle run all the way to redline in a single gear (second works fine). Group 002 usually shows air mass in g/s (in many modern ECU's, consult your Factory Repair Manual for the specific group for your particular vehicle). Your peak airflow should be roughly 0.80 times your horsepower. So, if you have a stock 150 hp 1.8T, expect around 120 g/s. If you see significantly less than that, you MAF may be on the way out.
    I will try 3rd&4th as suggested but i ran it today on my own and man its fast red lining in 3rd&4th , i had my son read the lap top in the rear of the car last time but i dont fancy them speeds with him in the car so i will have to get another bod.
  5. Re: MAF oppinions
    135 Post(s)
    2036 Post(s)
    Isn’t it a lot easier to just fit a new genuine MAF?
  6. Re: MAF oppinions
    Runcorn,Cheshire
    If i knew it was the maf yes..but if its not, its a waste of £62 don't you think??
    rstuning- dunno i will try it,cheers
    Davec
  7. Re: MAF oppinions
    May 2007
    Leeds
    Quote Originally Posted by davec573 View Post
    Ok, unokug the MAF, does it go better?
  8. Re: MAF oppinions
    Runcorn,Cheshire
    Unplugged it and its very erratic/pulsing up & down from normal idle 1000rpm ish dropping to allmost cutting out.
    engine management light up again today,seems to be every 100mls,i'll post up my scan.
    Davec
  9. Re: MAF oppinions
    Runcorn,Cheshire
    Davec
    heres the scan...
    VAG-COM Version: Release 409.1-US
    Control Module Part Number: 8E0 906 018 B
    Component and/or Version: 1.8L R4/5VT 0003
    Software Coding: 11701
    Work Shop Code: WSC 63351
    Additional Info: WAUZZZ8EZ1A026150 AUZ6Z0A0012083
    2 Faults Found:
    17544 - Fuel Trim: Bank 1 (Add): System too Lean
    P1136 - 35-00 - -
    16486 - Shareware Version. To Decode all DTCs
    P0102 - 35-10 - Please Register/Activate - Intermittent
    and a screen dump from measuring blocks at idle...
