Thread: A4 Abs Kickback Problems
Results 1 to 9 of 9
  1. A4 Abs Kickback Problems
    Hi, ever since i replaced the rear pads and discs on the rear of my a4 avant y plate iam having like a "bong" through the brake pedal, i have been told this is kickback.I have had the car diagnostically read but no problems show up with the abs, ihave had the sensors cleaned at the rear to no avail,please help!
  2. Re: A4 Abs Kickback Problems
    paul20v Guest
    have you cleaned the abs rings as well , i had this problem just as you pull up to a stop the abs would rattle on me , the rings were dirty and the abs was misreading them slightly
  3. Re: A4 Abs Kickback Problems
    hi, thanks for reply,do you think it is worth replacing abs rings?
  4. Re: A4 Abs Kickback Problems
    paul20v Guest
    Quote Originally Posted by fatfighter View Post
    no give them a good clean , they are part of the cv joint so renewing them would mean new cv joints, try blowing them off with an air line first ,if not pull the shafts and wire brush them ,
    hope this helps
  5. Re: A4 Abs Kickback Problems
    Aug 2007
    Cork, Ireland
    Also check the gap between the sensor and the ring.
    4 Audi's or is it 4 Audi?
    02 - A6 Avant 1.9 TDi 130 Sport
    01 - A4 Avant 1.8T Sport
    98 - A4 Avant 1.8 SE - Bye bye Bluey
    92 - 80 Saloon 2.0 - My first love (for 10 years)
  6. Re: A4 Abs Kickback Problems
    Mar 2007
    Quote Originally Posted by paul20v View Post
    hope this helps
    not on the rear they're not, but if you want to replace you'll need to heat them up to get them to expand enough to come of the inside of the discs.
    as advised tho, give them a good scrub with a wire brush first to see if that works.
  7. Re: A4 Abs Kickback Problems
    paul20v Guest
    Quote Originally Posted by darkhorse1001 View Post
    sorry my head was in front mode even thou i read the post DOH!
    the back ones are easy to remove they will tap off and back on really easy have done loads as said but dont heat them thou as heated metal is more prone to rusting,you can tap them off through the stud holes.
    i presume we are talking 2wd not 4wd , if 4wd drive were back to cv joints
  8. Re: A4 Abs Kickback Problems
    Mar 2007
    i did mine last autumn and they were so stubborn i ended up getting new rear discs to save the sweat and tears. maybe old discs weren't genuine though?
  9. Re: A4 Abs Kickback Problems
    del123 Guest
    I had that problem before, the abs rings were cracked. When I changed them the abs light stays on and the warning lighs flashes all the time,its a A4 1.9tdi 96 P plate. Any ideas what might be at fault?
