Thread: audi a8 2005 check navigation dvd msg on MMI
  1. audi a8 2005 check navigation dvd msg on MMI
    san francisco
    First time poster -- did a search with no results. Just bought a 2005 A8 which I love. Nav was working when bought and now get "check navigation DVD" Removed DVD and cleaned but no change. Power was off due to battery disconnect --- could this be the cause?
    Thanks for any advice
  2. Re: audi a8 2005 check navigation dvd msg on MMI
    Aug 2007
    The head on the DVD player could be dirty, try getting a cleaner disk.
  3. Re: audi a8 2005 check navigation dvd msg on MMI
    May 2007
    knee deep in clunge
    14 Post(s)
    iRead the measured value block 07 of the navigation. The value 03 indicates a correct access to the DVD. also consider the cdrom is damaged or the dvd drive unit defective.You have disconnected the battery so carry out a loop break test to ensure the optical circuit is ok and erase fault memory and cycle the igntion and repeat auto scan test,also reset the mmi via the setup return and soft touch key(its in the owners hand book)it will wake the networks up and possibly reboot the nav.If the nav unit is disconnected the fibre optic(most network)will store a fault as the loop has been broken.Or take it to your local Audi authorised A8 dealership for A8 licensed tech to check it.
  4. Re: audi a8 2005 check navigation dvd msg on MMI
    san francisco
    My thanks to hagis and a8 tech for quick replies. I'll work on it when I return home. Really glad I found this forum.
  1. Audi A6 2.0 TDi 2005 'juddering' clutch
    By Mark Carter in forum Chat - Completely Off Topic
    Last Post: 12-01-2009, 11:05 PM
  2. Bio-Fuel - check! V8 - check! 1000 bhp - check!.....
    By Sam in forum Chat - Anything with wheels
    Last Post: 03-12-2007, 04:29 PM
  3. audi a3 navigation plus
    By rsharr88 in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 25-09-2007, 08:57 PM
  4. Audi Navigation Vs Audi Navigation Plus
    By CTurbinado in forum Audi A3 - Archive Topics
    Last Post: 24-09-2007, 12:30 PM
  5. AUDI UK ENDS 2005 ON ITS BEST HIGH TO DATE
    Last Post: 23-12-2005, 09:27 PM
