Thread: Oil questions - A4 tdi 130
Results 1 to 10 of 13
  1. Oil questions - A4 tdi 130
    Hi All
    I have trawled the forum to find these answers, but no joy..
    - how much oil is needed for an oil service?
    - is Mobil 1 0w-40 'Turbo Diesel' Fully Synth a good oil to use?
    Car is 2002 A4 1.9 tdi 130 Avant, 5sp manual.
    Thanks!
  2. Re: Oil questions - A4 tdi 130
    133 Post(s)
    1986 Post(s)
    On Longlife intervals the oil must conform to VW standard 507 00 or 506 01 and on normal intervals 505 01.
  3. Re: Oil questions - A4 tdi 130
    It seems that Mobil 1 0w-40 is endorsed as VW 502.00/505.00/503.01.
    Would that make it ok for normal service intervals?
    i.e. it doesn't say 505.01 as you have mentioned.
  4. Re: Oil questions - A4 tdi 130
    133 Post(s)
    1986 Post(s)
    502 00 is petrol engine on fixed interval, 505 00 is NON PD TDI and 503.01 is petrol engine Longlife so it is NOT PD suitable.
  5. Re: Oil questions - A4 tdi 130
    Thanks for the explanation Crasher! Clear as a bell!
    I think I heard before that the car takes 5.5L to fill. Would you know if that's accurate?
  6. Re: Oil questions - A4 tdi 130
    133 Post(s)
    1986 Post(s)
    Just under five litres normally. We use VAG Quantum PD (normal interval) or Longlife III and there is very little left in the can after filling.
  7. Re: Oil questions - A4 tdi 130
    Mar 2007
    Lancashire
    You may be able to clarify here please. I've trawled info from many resources re oil and am aware of the .01 spec for PD engines. What many other forums endorse is using a fully synthetic oil. I use Millers XFE-PD which is 505.01 and 5w40. This is high synthetic, not fully. Fully tends to be 5w30? I drain every 6 months or 6k miles with a new filter. May be excessive but for £35 I'm sure the engine appreciates it.
    I can't see a reason for spending extra on fully synthetic unless the car really should using 5w30?? The above oil meets VWs spec.
    Marco
    A4 1.9TDI 160bhp Sport - 2001 (51)
    Re-map by more-bhp.
    TT 3.2 V6 DSG quattro 270BHP - 2003 (53)
  8. Re: Oil questions - A4 tdi 130
    133 Post(s)
    1986 Post(s)
    We use Quantum PD on that sort of schedule. The only engine I get funny about not using a fully synth on is the Golf 150PD and I recommend those still have 10k oil changes even on long life oil.
  9. Re: Oil questions - A4 tdi 130
    So I went to the part supplier today and bought Fuchs Titan SuperSyn Long Life 0w-30. This meets the 503.00, 506.00 and 506.01 standards.
    They also had Fuchs Titan PD 5w-30 which is 505.01, and nearly half the price.
    The guy recommended that for 12 month or 10k service intervals (which I have been following - I don't like to leave oil for longer than 10k miles), that I should spend the little more and get the better oil. I tended to agree with him.
    What do you guys reckon?
  10. Re: Oil questions - A4 tdi 130
    133 Post(s)
    1986 Post(s)
    Agreed, cheap insurance against cam failure.
  1. V5 questions..
    By Plug in forum Golf MK4 - 1999 - 2004
    Last Post: 25-11-2007, 09:04 PM
  2. MFD Sat Nav Questions
    By nick5golfs in forum Golf MK4 - 1999 - 2004
    Last Post: 22-11-2007, 01:43 PM
  3. Few questions......
    By Sisson in forum Passat - B5 Forum - 1997 -2005
    Last Post: 18-09-2007, 12:46 PM
  4. sat nav questions!
    By franky in forum Passat - B5 Forum - 1997 -2005
    Last Post: 08-04-2007, 09:15 AM
  5. Few questions!
    Last Post: 05-04-2007, 09:06 AM
