Thread: juddering or missfire
Results 1 to 10 of 12
  1. juddering or missfire
    Nov 2006
    lancashire
    hi all new to forum
    have a 1994 audi 80 tdi 1z engine,
    juddering at 1500 revs in 4+5th gears at light throttle.
    can anyone help.
    thanks ken.
    Nov 2006
    Oldham, Manchester, UK
    Could be faulty throttle position switch, engine mountings, fuel filters, water in fuel, air in fuel. Might even be something else mate but any one of the above could be a possibility.
    Cheers,
    Marc.
    Nov 2006
    lancashire
    Quote Originally Posted by Marc97 View Post
    Cheers,
    Marc.
    thanks for reply checked most what you say, but not checked throttle switch but will do
    thanks ken.
    Nov 2006
    Don't forget to let us know what it was when it gets fixed, its good for reference.
    Cheers,
    Marc.
    Apr 2007
    Hull
    I have a Audi 80 tdi 1992. had the same problem, but with not alot of power also! changed the fuel filter today, and the guddering as gone! but still no power. getting it checked tom, so hopefully will have some more answers.
    hi the juddering well iv cleaned out the inlet manifold and was it bad took a good cpl hours but well worth it also cleaned out the injectors new return pipes as old ones brittle all new vaccume hoses fitted its almost gone i say almost i also cleaned the maf with electrical contact cleaner and now lots more power more driveable and economical and no smoke so if u want to try any or all of these its well worh it u will notice a diffrence overall i tried diffrent n75s too but still running in the origanal onemight clean the intercooler next, if i sort it ill let u all know good luck
    kev
    Apr 2007
    Ards, Northern Ireland
    I think i might need to try cleaning out some of my bits! Is electrical contact cleaner the best thing to use on the maf? I suppose good old wd40 would damage it? lol
    nooooooooo nooooo noooooo not wd40 i used electrical contact cleaner that alone made a big difrence to the smoke, the inlet manifold was thick and well worth doing i droped the exhaust manifold with the turbo made it easer to get at took bout 3 hours altho am hour of that was shiftind the crud out of it go for it you will notice the diffrence
  9. Re: juddering or missfire
    hi ken, yeh i had same intermitant problem, replaced sensor in front of turbo, part no:-028 906283, and this has cured the problem.
    regards
    mark. audi 80tdi 1995
  10. Re: juddering or missfire
    lancashire
    first timer hello all judderers and judderets i to have symptons of the judders power loss on hills .tried new maf or mas , new boost pipe ,changed egr valve, replaced thin vac pipes, blanked off egr serviced regular ,turbo whistles like jethro hurding sheep in .do they alwhistle can i make juddering history jay
  1. mysterious occausional missfire/shuddering
    By quattro kev in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 15-06-2007, 08:50 PM
  2. missfire/judder
    By markkk1965 in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 03-05-2007, 10:19 PM
  3. Juddering S4
    By Lenny75 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 10-04-2007, 06:28 PM
  4. 2000 1.8t missfire. Fuel starvation ??
    By jasonkay in forum Passat - Archive Topics
    Last Post: 01-02-2007, 09:10 PM
  5. Juddering C
    By JBOB in forum Scirocco - Corrado
    Last Post: 13-06-2005, 06:00 PM
