Thread: ABS fault from vag-com
Page 1 of 3 123 LastLast
Results 1 to 10 of 30
  1. ABS fault from vag-com
    Nov 2006
    vag-com scan produces:
    Address 03: ABS Brakes
    Controller: 8E0 614 517
    Component: ABS/ESP front 3429
    Coding: 04155
    Shop #: WSC 06435
    1 Fault Found:
    65535 - Internal Control Module Memory Error
    00-00 - -
    There are no faults on the DIS. I understand the unit could be defective and has to be replaced? Is there a danger if I don't get the part replaced? I guess it can't be cleared with vag-com?
    Cheers.
  2. Re: ABS fault from vag-com
    135 Post(s)
    2026 Post(s)
    Is the ABS light on?
  3. Re: ABS fault from vag-com
    Nov 2006
    Hi Crasher,
    Sorry for posting twice! No, the ABS light is not on. When I scanned the car the big red ABS light on the DIS came on at the same time when vag-com reported the fault (it blinked about 3 times and went off). At the moment, there is no ABS light on. I'll get the unit replaced (my warranty covers ABS systems) but I was worried in the meantime that the ABS was not working.
    Cheers.
  4. Re: ABS fault from vag-com
    135 Post(s)
    2026 Post(s)
    If the ABS light is off the system should be functioning so it is odd that you have such a severe fault code and the light isn't on.
  5. Re: ABS fault from vag-com
    hi,i had this fault code come up when i used vagcom on my a4 cab,along with 00526-brake light switch-f.My abs light is on constantly,is this an abs module prob? many thanks
  6. Re: ABS fault from vag-com
    135 Post(s)
    2026 Post(s)
    Possibly.
  7. Re: ABS fault from vag-com
    Nov 2006
    Just tried to clear this fault but couldn't because I have the shareware version.
    The car's going in for a service soon, so I'll ask the garage to scan the car and clear any faults. As mentioned before, there are no ABS faults showing on the instrument display or DIS.
  8. Re: ABS fault from vag-com
    Magdeburg, Germany
    The fault code not being cleared is NOT a shareware limitation.
    http://wiki.ross-tech.com/index.php/65535
    In terms of danger, personally I would get this fixed/replaced ASAP.
    Sebastian @ www.Ross-Tech.com
  9. Re: ABS fault from vag-com
    Nov 2006
    Could it be that I cannot clear the fault because the lead I have is not a ross-tech one but one bought from ebay? I'm pretty sure when I tried to clear the fault, the software complained about permissions and limitations as to clearing DTCs.
    To quote Crasher:
    "If the ABS light is off the system should be functioning so it is odd that you have such a severe fault code and the light isn't on".
    I'm not convinced this is a real fault even though vag-com is reporting it. The ABS light should be on but it isn't. I know the light works because it came on during the vag-com scan to report the fault.
    I'll get the dealer to scan the car and report back any faults during the service.
  10. Re: ABS fault from vag-com
    Magdeburg, Germany
    There is no reason for VAG-COM to report this unless you were trying to use the "clear all" button on the Auto-Scan screen. Normally you should use it like this...
    VAG-COM > Select > 03 - Brakes > Fault Codes - 02 > Clear Codes
  1. abs fault!!!?????
    By drew smith in forum Audi A3 - Archive Topics
    Last Post: 13-02-2008, 04:40 PM
  2. ESP Fault
    By jb8591 in forum Golf MK5 - 2004 - 2009
    Last Post: 30-11-2007, 06:50 PM
  3. Air con fault - help!!
    By LeeinBunwell in forum New Member Introductions
    Last Post: 13-10-2007, 07:59 PM
  4. Abs Fault..... Please Help!!!
    By sels bora in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 16-04-2007, 08:54 AM
  5. T Reg Passat - Electrical Fault, Remote Central Locking Fault
    By adriana in forum Passat - Archive Topics
    Last Post: 01-03-2007, 06:27 PM
