Thread: 130 r 150 Mk4?
Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
  1. Re: 130 r 150 Mk4?
    Dec 2007
    New Mills, Derbyshire
    Most G4 diesels were built in Belgium.
    Oh!
    Well my Belgum built ARL isnt having to work quite as hard now, as my Golf is lovely and clean - until it rains anytime tonight!
    150 GTI DIESEL - propper juice!!
  2. Re: 130 r 150 Mk4?
    Feb 2005
    Selby, North Yorkshire
    I've had both in Bora Sport form and there's nothing to choose between them spec wise. Golfs are quite a bit different in GT format though I believe.
    150 is definitely quicker, but the 130 suffers less lag on pick up. Economy is similar (i think 150 is actually better at motorway speeds), but as Crasher points out, for some reason, the ARL eats cams/follows and the turbo's are less reliable.
    Mind you, my 130 has just cost me a flaming fortune, but mostly wear and tear items such as clutch, bushes etc.
    I prefer the 130 to drive, but that's just my opinion, go and test drive both - you'll buy a 150 because you won't be able to resist the extra grunt!
  3. Re: 130 r 150 Mk4?
    Rhode, Ireland
    Wow. Not much in the the difference so. Being only 21 and lving in Ireland, I think il have to settle for the 130 lump (for crazy insurance premium reasons). So purchased a 2003. 56K on the clock. One little problem, bringing it past 3500rpm, the turbo stops operating ()until i switch off the ignition and back on again. not cool when pulling away from the lights. any ideas?? im thinking maybe an electrical connection.
  4. Re: 130 r 150 Mk4?
    Lincoln
    Quote Originally Posted by devsgolf View Post
    probably a hole in the turbo pipe mine rubbed against the drive shaft..
    It was the pipe leadin to the bottom of the vnt.. it runs up/down the back of the engine next to a big black pipe and the only one that goes down the back(drivers side) i traced it back to a join and took it off and sucked it did not hold pressure so easy diagnosis for me.
    http://www.tyresmoke.net/ubbthreads/...0/fpart/1/vc/1
    I started here when I first started gettin problems hope its of some help.
    but I am sure in this forum there is loads a posts relating to it as it seems quite a regular problem
  5. Re: 130 r 150 Mk4?
    133 Post(s)
    1982 Post(s)
    A fault code read will give you code, 17965 over boost error, which will be sooted up and sticking turbo vanes, probably the reason it was sold.
  6. Re: 130 r 150 Mk4?
    Lincoln
    mine was an overboost crasher cant remember for sure but think Ihad that code. is it possible to be what I said
    in my last post? I aint no mechanic even my vw buddy mechanic said it was not possible t be a holed pipe but followin the advice in the link I posted it was tracked down to the pipe.
    one of the first things I did was see how free the vnt mechanism was dint fancy stripin a turbo down.
    I was gleemin for weeks.
