Thread: CV JOINT or Wheel Bearings
  1. CV JOINT or Wheel Bearings
    Jul 2007
    Hi !
    I have an weird noise at the moment which becomes more noticeable when steering slightly e.g a bend in the road or tightly e.g. a roundabout
    There is no vibration through the steering wheel
    The noise is hard to explain, it is NOT a knocking noise and neither would I say it was more of a rubbing noise. The noise is related to speed because the noise gets quicker or slower according to my speed.
    I know that play in the wheel would indicate a wheel bearing so I will be checking this on the weekend, but a friend suggested whether it could be a CV joint gone ?
    However, (A) I dont know the symptoms and (B) how you can check to see if it is gone I wouldnt know.
    Does anybody know the symptoms of wheel bearings or CV joints worn and secondly how you can actually check ?
    Cheers!
    Brett
  2. Re: CV JOINT or Wheel Bearings
    Gwent
    I would describe outer cv joint noise as being a 'clack, clack clack' type of noise, it usually happens worst when the steering is at or near full lock and the throttle is applied. A really bad joint will do this at lesser steering angles, eg accelerating out of roundabouts. If it is making this type of noise, go around in tight circles to cause the noise and have somebody listen out for which side.
    A wheel bearing usually makes a humming noise and sometimes it will get quieter/louder as you go around bends, this is because the weight tends to transfer from the inside wheel to the outside wheel, when cornering. You might be able to use this to work out which side is making the noise.
    2001 Passat Sport tdi 130hp
    1990 Audi coupe 20v x 2
  3. Re: CV JOINT or Wheel Bearings
    I had both cv joints changed on my audi 80 cab one after the other heard clicking noise usually if you checking condition of rubber bellows that house cv joint are in gives you some indication of the condition of cv joint .ie if they are torn and split then leakage of grease from bellows may have caused CV joint to run dry and deteriorate
  4. Re: CV JOINT or Wheel Bearings
    Sep 2011
    Isle of Man
    yep, definitely wheel bearings
  1. Audi 80 wheel bearings
    By diamondbrit73 in forum 80 - 90
    Last Post: 23-02-2010, 12:02 AM
  2. front wheel bearings
    By shorty in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 20-02-2008, 09:17 PM
  3. Rear Wheel Bearings
    By roobarbii in forum Passat - B5 Forum - 1997 -2005
    Last Post: 02-07-2007, 05:56 PM
  4. Passat W8 wheel bearings
    By daniel in forum Passat - Archive Topics
    Last Post: 02-02-2007, 06:14 PM
