Thread: tdi hesitation
Results 1 to 10 of 19
  1. tdi hesitation
    Mar 2007
    hi i have a a4 tdi 90 engine code ahu. every now and then it starts to shudder, it only does it between 1200-1500 and normally under light load, if i put my foot down its fine, i've had a new maf and theres no fault codes, any ideas?
    thanks
    mike
  2. Post Re: tdi hesitation
    Mar 2008
    Northampton
    Hi Mike,
    I have a 2000W 1.9TDI 115 SE A4 with exactly the same problem. I’ve just joined the forum to hopefully find a solution!. I took the car to a local VAG specialist and they tried a few things over the course of a day and a half. Service history is perfect, always used VAG parts and oil etc. New MAF fitted last year too. The garage checked, compression, fuel lines, filters swapped out MAF etc etc. But still no joy! I’m able to make the car do it on demand (well coming off roundabouts anyway). I’m going to take one of the engineers out to show them the problem as they seemed to have difficulty in getting the shudder/judder to happen. Mine seems to start judder at about 950rpm through to 1500, very light throttle regardless of gear.
    I’m sorry I can’t help you here, but it’s nice to know I’m not the only one! I’ll keep you posted with any findings (won’t be for a couple of weeks though). Please let me know if you get any joy in resolving the issue.
    Cheers Graeme
  3. Re: tdi hesitation
    Mar 2007
    i've managed to find my problem, it was a vacuum hose that goes onto the airfiler box, it wasn't even attatched, I pushed it back on and its been fine since, hope you find out yours mate
  4. Post Re: tdi hesitation
    Mar 2008
    Northampton
    Interesting... I’ll take a look, this problem is doing my head in.
    Many thanks.
  5. Re: tdi hesitation
    Jul 2007
    ive got the same problem with my a4 115 tdi 2000 w read how far we have gone to get rid of this problem fly wheel, injectors,filters maf,loads of money spent ive posted many times about it with no real response
  6. Thumbs down Re: tdi hesitation
    hay im new to this aswell, and from what i see we are all having similar problems only i have by passed all the problems you are having and i am now at the car cutting out when you rev it over 3 rpm and taking two three attempts to start! i also have a 1.9tdi 90 ahu on a 99plate! audi seem to have never heard of the problem, its frustrating me not having the car and whats even worse is i come on this and find many with tha same problem!!!
    i have had the diesel pump re-cond, glow plugs, timming belt, new cam pully, then new piston two new valves head skimmed and it dropped a valve again so i got a new engine which was checked in the old car before swap and ran fine but still wouldnt rev past 3rpm in my car! i also had the ecu sent away to be re-cond and still no difference i have only had the car since november and i am throwing money at it now!!! (which i dont have) today the accelerator pedal is being changed as it is fly by wire and the box is on the side of the pedal so i will post if i have any joy
    sorry for the rant!
  7. Re: tdi hesitation
    Jul 2007
    please let us no how you get on. i have blanket off the egr valve today took off the inlet manifold cleaned it new filter checked all the loom in the head again!checked every pipe i can see this car is driving me insane i hate this car! This car is fine and revs fine until you drive it!
  8. Thumbs down Re: tdi hesitation
    hay, well no joy it didnt make the slightest bit of difference!!!! its booked into a diesel specialist on monday who has just had an audi b5 in for the past four months, so hopefully he knows the problem as he certainly wont be having my car that long!!!!! again if i have any success i will let you all know!
    i think we should all join forces and approch audi with the problems we are having! (with guns lol) not
  9. Re: tdi hesitation
    Dec 2007
    8 Post(s)
    Hello
    Audi 80 TDI 1994 model suffers same problems
    More info @
    Audi 80 TDI Juddering Bucking Jerking
    Audi 80 TDI Estate -are they any good
    Juddering or Missfire
    Audi 80 TDI Juddering Problem
    Audi 80 TDI Bucking Jerking
  10. Re: tdi hesitation
    Audidothat Guest
    Quote Originally Posted by graememwagg View Post
    Hi Mike,
    Cheers Graeme
    Hi Graeme
    Got the same car with the same problem, although mine at the moment is intermittent. Just wondering how you got on... Mines going in Wednesday, would be nice to know what to expect..
    Regards
    Martin
  1. Cold Hesitation
    By Jeevsey in forum Golf MK3 - 1993 - 1999
    Last Post: 14-02-2008, 01:58 PM
  2. Hesitation on acceleration
    By yenool yar in forum Audi A4 - Archive Topics
    Last Post: 12-02-2008, 10:26 PM
  3. Engine hesitation 1.9 tdi 130
    By mneale in forum Passat - Archive Topics
    Last Post: 22-10-2007, 09:17 AM
  4. golf 96 2L 16v hesitation
    By pagey in forum Chat - Anything with wheels
    Last Post: 02-03-2007, 02:26 PM
  5. 1.8T No power / Hesitation!
    By gaffer in forum Archive posts
    Last Post: 12-09-2006, 07:12 PM
